Need to decide
Old Apr 9, 2021 | 09:45 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Deleted
Old Apr 9, 2021 | 01:20 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by SconnieRider
Can't speak for the OP, but I did the swap for the longevity of the hydraulic tensioner verses the spring loaded ones. Another reason is for the precision of the forged plate verses the cast OE one, which can cause seal issues. And the better performing oil pump that came with it was a nice upgrade.
Well if you are running a 0.660 lift cam with heavy spring it might be worthwhile but I'd probably go to gears in that case.
Old Apr 9, 2021 | 01:22 PM
Max Headflow
Originally Posted by tinymike66
I had that installed before ....it got ruined
I don't think the tech centered the pump n it chewed the plate.
I tore engine apart
Checked runoutDrained and flushed casesDid oil analysis
Now that I know everythjng else is ok....I'm upgrading to 98
New camsNew pistons
Converted it from mm efi to carb.
Got a pic?
Old Apr 9, 2021 | 02:42 PM
tinymike66's Avatar
tinymike66
Got a pic?
Of cam plate?
Old Apr 9, 2021 | 07:08 PM
Max Headflow
Of cam plate?
Yes sir. Where it's bad.
showin4fun
Engine Mechanical Topics
Aug 23, 2019 07:30 PM
jmn1960
May 21, 2013 04:58 AM
Tripp_HPjunkie
Mar 22, 2013 06:57 AM
jackinthebox
Oct 28, 2010 09:40 PM
18BKLR
Oct 16, 2010 09:57 PM
