Need to decide
Old Apr 7, 2021 | 04:14 PM
tinymike66's Avatar
tinymike66
Default Need to decide
Hi all,
it's time to order oil pump and cam plate
Screaming Eagle kit? $644 cad
S&S kit? $970 cad
Fueling kit? $1079 cad
Which one and why?
Old Apr 8, 2021 | 10:46 AM
tinymike66's Avatar
tinymike66
Anyone got an opinion or take on this?
Old Apr 8, 2021 | 11:11 AM
Scudda's Avatar
Scudda
I went with the SE kit, never really looked at the others
Old Apr 8, 2021 | 11:59 AM
tinymike66's Avatar
tinymike66
Thank you
Old Apr 8, 2021 | 12:00 PM
SconnieRider's Avatar
SconnieRider
Just installed the SE kit over the winter and like it. Can't speak to the other two, but any one is going to be better than the cast OEM. I ended up heating up the plate with a torch to install the bearings instead of pressing then in.
Old Apr 8, 2021 | 07:42 PM
TracerBullet's Avatar
TracerBullet
SE stuff here. No complaints
Old Apr 8, 2021 | 11:15 PM
Max Headflow's Avatar
Max Headflow
Unless you have an urge to get rid of the old spring loaded tensioners, why switch?
Old Apr 9, 2021 | 06:01 AM
SconnieRider
Can't speak for the OP, but I did the swap for the longevity of the hydraulic tensioner verses the spring loaded ones. Another reason is for the precision of the forged plate verses the cast OE one, which can cause seal issues. And the better performing oil pump that came with it was a nice upgrade.
Old Apr 9, 2021 | 08:24 AM
tinymike66's Avatar
tinymike66
I had that installed before ....it got ruined
I don't think the tech centered the pump n it chewed the plate.
I tore engine apart
Checked runoutDrained and flushed casesDid oil analysis
Now that I know everythjng else is ok....I'm upgrading to 98
New camsNew pistons
Converted it from mm efi to carb.
Old Apr 9, 2021 | 08:57 AM
MACDBF's Avatar
MACDBF
I have the fueling conversion kit in mine. It's been a year and have had no problems. My buddy recommended them, so that was the reason I chose them. Great product, and had no issues with fit and install!
Mac
