Your thoughts on adding set screws to handle bar clamp .
Old Apr 16, 2021 | 07:58 AM
MyFavRk's Avatar
MyFavRk
Default Your thoughts on adding set screws to handle bar clamp .
I just started installing a set of 1-1/4" , 12" mini apes on my bike . I got to thinking about whether or not I need to upgrade the clamp , so the bars don't slip .
Is there any reason I shouldn't drill and tap a couple set-screws in it , or should I just leave it alone ? I did have a set of 10" bars on before with no issues .
Old Apr 16, 2021 | 08:01 AM
perki48's Avatar
perki48
Go for it, if you have a big desire to WEAKEN your clamps.
Old Apr 16, 2021 | 08:04 AM
major105bc's Avatar
major105bc
I had to pin a set of 16" apes that I put on my 02 Heritage Springer. Makes a world of difference. The bars don't budge. Only had to do one riser. The second is overkill.
Old Apr 16, 2021 | 08:08 AM
bustert's Avatar
bustert
see no need, never had a pair of proper bars slip. before i would add set screws which will mar the bars which makes changing position in the future a little more work removing the raised metal, i would add a wrap of crocus clothe with the grit to the bar side.
Old Apr 16, 2021 | 08:10 AM
MyFavRk's Avatar
MyFavRk
Yah , I was wondering about that , which is why I posted , I wanted to know if anyone has done it , and how it worked for them . Appreciate your response .
Old Apr 16, 2021 | 08:21 AM
MyFavRk's Avatar
MyFavRk
The more I think about it , I will probably just end up installing the bars according to the manual , the front 2 bolts need to be torqued first before the rear , seems this helps fasten the bars down a little stronger instead of an even gap all around . Since I do all my own work , I'll just leave well enough alone , if I do have any slip , I'll buy a beefier clamp .
Old Apr 16, 2021 | 08:27 AM
Architect's Avatar
Architect
Does your bike you a two piece or one piece top clamp?
My '05 Roadie had a two piece, I bought a one piece, cheapo black one from J&P when I did a set of 12's. Something like $15, never moved. Plus it gives you a little more stability from racking. Good luck.
Old Apr 16, 2021 | 08:38 AM
RANGER73's Avatar
RANGER73
When I did my 14’s they moved. Thought of drilling and tapping but went with a premade clamp with the set screws already installed.
Old Apr 16, 2021 | 08:41 AM
MyFavRk's Avatar
MyFavRk
My '05 Roadie had a two piece, I bought a one piece, cheapo black one from J&P when I did a set of 12's. Something like $15, never moved. Plus it gives you a little more stability.
Good question , it's a one peace clamp , which is why I originally thought about the set screws instead of buying a new clamp , but like perk stated , it may weaken the clamp , they are definitely thinner than the aftermarket ones I've been seeing .
Old Apr 16, 2021 | 12:56 PM
eighteight's Avatar
eighteight
I see no issue with adding screws.
JMO
