TwinCam getting hot
Old Jul 6, 2021 | 05:03 PM
Summers_streetbob's Avatar
Summers_streetbob
Stage III
Default TwinCam getting hot
So my 2017 TC streetbob frequently gets over 250 degrees on the highway. If I try to run through town the bike jumps up to 280 easily even with the fan running. So my mods are Woods tw222 cam, S&S oil pump and cam plate, DK customs fan assisted 10 row oil cooler, 2-2 pipes,SE high flow intake, power vision with wideband sensors. I’m under the impression that ideally the bike shouldn’t go to much over 230 degrees.
What am I doing wrong with this thing?
Old Jul 6, 2021 | 05:07 PM
JustDave13's Avatar
JustDave13
It's a TC they run hot, I've rode mine all over the south west without any problem.
BTW if you're reading the head temp those numbers are normal.
Old Jul 6, 2021 | 05:16 PM
MURPHCC1's Avatar
MURPHCC1
Welcome aboard from Old Cape Cod!!!
Those are normal temps if you're reading from Powervision, I get the same temps depending on outside temp.
Old Jul 6, 2021 | 06:58 PM
Summers_streetbob
Stage III
Yes those were the engine temps coming from the power vision. The head temps generally are 320-350ish.
I appreciate the quick response. I was under the impression that the engine temp needs to stay under 230 or you could have some engine problems.
I guess I had higher expectations of the oil cooler when I put that on.
Old Jul 6, 2021 | 10:09 PM
Max Headflow's Avatar
Max Headflow
Nope oil temps are nice to keep under 230.. The engine temps are the temp of the front head intake side. It can get to 280 in traffic easy.
Old Jul 8, 2021 | 09:38 AM
60Gunner's Avatar
60Gunner
Depending on ambient temps and how hard you ride, engine temps north of 300°F are well within the realm of normal.
Old Jul 14, 2021 | 08:43 PM
Taxgod4u's Avatar
Taxgod4u
Summers, did the 10 row fan assist cooler make any difference in oil temp?
Old Jul 16, 2021 | 10:48 AM
Bandit.'s Avatar
Bandit.
Just don't stop and it'll stay cool. Sitting at the light in 90-100 degrees is the worst. But it is part of the ride.
Old Jul 16, 2021 | 12:39 PM
Summers_streetbob
Stage III
It cools down a lot faster when I hit the highway than without the cooler but I don’t think the fan pulls enough air through to make a difference if you’re in stop and go traffic.
Old Jul 16, 2021 | 01:47 PM
Trumpet's Avatar
Trumpet
I'd been fighting with heat off the bike since last summer. Seemed to almost torch the left leg of my jeans and redden the skin underneath from the heat.
I started reading up on PV-1 settings and options and chose to do the following: Tuned basic global fueling +2% and low revs fuel +3%. Big difference in heat at idle /low speed operation, no more burning thigh in traffic. Bike runs smoother across all revs.
Stock 96 tc Ultra, stock exhaust, Fuel moto air filter setup. PV-1 with FM's recommended tune.
