Starter
Old Nov 3, 2021 | 08:20 AM
bustert's Avatar
bustert
on the communtator, make sure the insulators are below the surface. the carbon tracking can be removed with fine paper abrasive suitable for metal. i usually will chuck it up in a lathe to maintain truness. do not forget to service the bearings and check brush length.
Old Nov 4, 2021 | 05:32 AM
PLANET HARLEY's Avatar
PLANET HARLEY
Hi
I have a problem with the assembly of this part
or
thanks
Old Nov 4, 2021 | 07:28 AM
eighteight's Avatar
eighteight
33 minute Youtube video on the process will certainly help you more than I can
Old Nov 5, 2021 | 12:37 PM
PLANET HARLEY
Hi
I still have the same problem.
the starter lacks torque
Old Nov 5, 2021 | 12:51 PM
eighteight's Avatar
eighteight
Model & year of bike ?
Stock or modified ? ( i.e. increased compression )
How many miles ?
How long have you had the bike ?
How long has it displayed the problem ?
Have you checked the condition and connections of the battery cables ? I assume yes as you`ve had the battery and starter "out"
Especially the grounds
Is your new battery fully charged ?
Do you know the battery is good ? There is such a thing as "new defective". load tested ?
Describe problem in more detail
Cranks slow when engine is hot ? ( i.e. at a gas stop ?)
Always cranks slow ?
Won`t crank at all ?
Old Nov 5, 2021 | 03:36 PM
PLANET HARLEY
Model & year of bike ? 1340 heritage 1990
Stock or modified ? ( i.e. increased compression ) i dont Know
How many miles ? 70000
How long have you had the bike ? 1 month
How long has it displayed the problem ? 1 month
Especially the grounds :yes. I would post pictures
Is your new battery fully charged ? Yes
Do you know the battery is good ? There is such a thing as "new defective". load tested ?the battery is new.
I will test with another battery
Describe problem in more détail
the starter engages but not enough power to run the engine.
310A battery is this sufficient?
Old Nov 7, 2021 | 02:25 PM
PLANET HARLEY
I will buy a more powerful battery
https://eu.odysseybattery.com/product/ods-agm16lmj-2/
https://eu.odysseybattery.com/product/ods-agm15lmj-2/
Honda
Jul 5, 2021 07:42 PM
farmersemail
Ironhead
Apr 22, 2021 04:13 PM
General Hangover
Electrical/Lighting/Alarm
Mar 1, 2020 11:23 AM
David O'Connell
Jul 13, 2016 11:08 PM
imslypig
Oct 7, 2010 07:10 AM
