Starter solenoid doesn't run - but power is available?!
my 92 FHLS fails to start the engine. Pushing the starter button, I just hear a click in the relais - but no moving of the solenoid inside the coil. I removed the lid and want to narrow down the error.
I'm not quite sure, if I just have a simple poor electrical connection to the frame or whatever. If I take my voltmeter and check the voltage between the battery minus and the withdrawn plug #3 (see photo), it's 12V if starter button is pressed. Also the voltage between #1 and #2 is 12V and if I push the solenoid by hand, the starter engine gets power and start running. Where do I have to measure if I want to know, whether the voltage from plugged # 3 arrives where it belongs?
Regards
Jens
- The error occurred last summer. I helped over the saison with a solenoid cover with integrated push button.
- For other reasons I changed the engine in Winter. I had the checked starter from another bike and installed it.
- Now I have the same error pattern, even though I changed the whole starter.
Jens
I still think it's a ground fault. But how can I measure that?
The only to accurately check is to read the voltage on the circuit while it is under load.
When the connector is unplugged, the circuit only has to supply enough amperage to power the voltmeter, which draws only a few milliamps.
When the circuit is complete, it must supply 12 volts at a much higher amperage (whatever the solenoid pull in coils draw).
Test that circuit with the connectors hooked up to the relay and solenoid and see what you get.
To check ground in that circuit, touch the negative probe to the negative post on the battery, touch the positive probe to the starter mount bolt, press starter button, voltage should read zero. If you read any voltage, the ground is poor.
I did as you recommended and checked the ground. Everything is fine - no voltage.
The I made another simple test - I don't know why I didn't think of it earlier: I bridged directly to the plug #3 with the positive pole of the battery. The magnet moved in immediately, the starter got power and started to run. For mee - the starter is okay!Now I've to check the cables before the starter and relais. Any recommendations?
Regards
Jens
