Risers "loose"
Old Aug 5, 2022 | 09:08 PM
JatdinTheOG's Avatar
JatdinTheOG
6th Gear
So did all of my maintenance on my bike today. New oil/filter/intake filters (preparing for sale). I also tightened the risers and did loctite. Everything feels extremely secure now. Thanks guys!
Old Aug 6, 2022 | 07:45 PM
Max Headflow's Avatar
Max Headflow
It sounds like you don't have the spacer that goes inside the bushings to set rubber preload.. If you tighten it down, you'll likely squash the bushings and damage the riser / trees.
If you do have the spacer and the bolt gets tight but the bushings are still loose, you might want to trim some off the spacers. Also make sure that the bolts are not too long and bottoming out in the risers.
Clsd350
Aug 31, 2015 07:17 PM
Clifford05
Nov 10, 2014 07:08 PM
grantb
Ironhead
Sep 7, 2012 07:30 PM
BubbleGutZ
Mar 31, 2011 05:51 PM
lowrider284
Mar 11, 2009 04:28 PM
