Numbness
Old Aug 20, 2007 | 01:40 PM
JeffreyB's Avatar
JeffreyB
Default Numbness
This is almost embarassing... I just bought a new 08 Ultra a couple weeks ago. I have logged about 2300 miles so far.. I am having a problem with my groin area actually getting numb in as quick as 20 to 30 minutes of riding. Also I have a 93 Fatboy which I have logged about 116,000 miles on it and have done 1000 mile days with no problem.. On the Ultra I put highway pegs to change position I shift about a lot but nothing helps... I am hesitant to go out and spend big bucks on a new seat... Has anyone had similar problems on the Ultra
Old Sep 11, 2007 | 07:19 PM
dirtdobber's Avatar
dirtdobber
Default RE: Numbness
I would consider checking with www.meancitycycles.com to have your seat redone. Allen's work is great and whithin a timely manner. He uses memory foam. I had mine done and love it. Saved a lot of $$$. Another thing that might help and will give more leg room at the same time and low cost. Kuryakyn and HD makes floorboard extenisions. They push the floorboard out about 3/4" that will allow your legs not to be pushed into the tank. Makes it much more comfy and takes stress off of the inner thighs and hip joints. Gives more room for the family jewls
Old Sep 15, 2007 | 09:51 AM
thelawdoc's Avatar
thelawdoc
Adjust your riding posture so that you reduce the weight coming down to the perianeal area. You can lean forward just a tad and probably see a difference.
Old Sep 15, 2007 | 11:34 PM
sgt joseph's Avatar
sgt joseph
ORIGINAL: JeffreyB
Do not be embarrassed about this bro, i ride a bicycle about 150 to 200 miles a week, and have this happen on occassion, although i do not have the problem on a motorcycle ....Its VERY common in cycling....And the fix can be a few different things....For me, ibought a seat that had a slight channel or groove cut out in it which allows the bloodflow to not be cutoff in that thar area....Since getting this seat for my bicycle, the problem is not nearly as prevalent as it was....Also your riding position can also cause this to happen, and its relevant to where your **** is seated on the seat......On my bicycle, i occassionally stand up and pedal for a few minutes every 4 or 5 miles, to kinda let the blood flow a little easier to that area for a spell.....Good luck to you !
Old Sep 16, 2007 | 06:50 AM
Navychief's Avatar
Navychief
Since you say the fatboy doesn't bother you it doesn't sound like a circulation/medical problem, and that's a good thing. If the the highway pegas don't seem to help looks like you're gonna have to look into the seat for an answer. Before dropping bucks on a new seat, look at how you fit on the Fatboy, leg position, body angle, etc.. Lots of seat covers out there that may help get you into the same or similar position. If not, look to your friend that have aftermarket seats and see if they will let you sit their bike to see if it feels any better than your stock seat. If they're good friends and you leave your wife as a deposit they may let you put a few miles on the seat for a road test.
Old Sep 17, 2007 | 09:35 AM
pauletich's Avatar
pauletich
I would spend the extra bucks and have the seat re-foamed for you, you can get it done for under $100 and its money well spent.
Old Sep 30, 2007 | 07:10 PM
zuma's Avatar
zuma
I am a new rider and have numbness in my hands after about a half hour of riding. Does anyone know if new, larger grips will make a difference?
Thanks in advance.
zuma
Old Sep 30, 2007 | 08:42 PM
2deuce's Avatar
2deuce
Jeff, had the same thing with EG Classic...didn't get better in 8000 miles, so I went back to a Deuce. With me, I think it's the "cruising" position that makes a difference. Just couldn't find a seat that would drop me down enough to get the lean back tilt. I'd check into the suggestion of checking with Mean City Cycles
Mike flies
2018+ Softail Models
22
Apr 12, 2019 03:50 PM
Kevin Dearing
2014-2024 Touring Models
77
Aug 10, 2018 08:06 AM
MDSledhead
78
Jul 20, 2016 08:02 AM
ditch_dgr
Sep 6, 2009 07:48 AM
dragonx
May 12, 2008 03:52 PM
