Sometimes The Simplest Things...
Old Jun 13, 2023 | 09:35 AM
brakeless's Avatar
brakeless
Originally Posted by Ultra103
You're using the 'pipe dope' sealant as reccommended by the MoCo, right?
That must be something they came up with after my model year. For 19 years I've been doing it exactly the same way on this bike as per the genuine HD FSM. "Clean drain plug, install new o-ring, and tighten to 36-60 inch lbs." And it's always worked. Like I said, it's holding now so I'm not messing with it until the next fluid change! But yeah, pipe dope would probably work. I even considered teflon tape if I couldn't get it to stop.
Old Jun 16, 2023 | 12:05 AM
hvacgaspiping's Avatar
hvacgaspiping
...... During my career as an HVAC service tech I witnessed on several occasions that commercial plumbers use high quality pipe dope AND teflon tape. Their method is about 1 1/2 wraps of teflon tape around a male fitting and then lightly cover the whole thread surface with the pipe dope. I copied that whenever I needed to fit any pipe threads, and it always worked for me as well. The trick is not to use too much of either teflon tape or pipe dope.
Old Jun 16, 2023 | 05:39 AM
Rusty Springs's Avatar
Rusty Springs
If you install a new o-ring and install the plug hand tight you will feel the oring squeezing into the bevel. Once the plug is seated it should not leak.
Im not saying leave it hand tight and ride the bike. If you don't tighten it will fall out. If you turned a small o-ring boss plug a half turn after it seated the threads are damaged or the oring was pinched.
bugzapper
Nov 11, 2012 09:57 AM
mjrobinson
Oct 11, 2012 06:23 PM
dynagirl
Mar 24, 2008 07:15 PM
BONES206
Dec 26, 2007 06:35 PM
nukeguy
Feb 18, 2006 11:56 PM
