primary drain plug
Old Nov 8, 2011 | 05:35 PM
bugzapper's Avatar
bugzapper
Default primary drain plug
It seems like the primary drain plug is stripped out (the torx part). Last fluid change was done by an indy and I can't get it loose. Any suggestions on how to get it out would be greatly appreciated. I really don't want to take it back to the same guy again, I'm starting to wonder if he really changed it last time.
Old Nov 8, 2011 | 05:50 PM
dyna rider's Avatar
dyna rider
Default Primary Drain
Try a 5/8" box end wrench. Careful not to over torque it when you reinstall.
Old Nov 8, 2011 | 06:41 PM
bugzapper's Avatar
bugzapper
This is the primary drain, it fits flush to the bottom of the case under the clutch.
Old Nov 8, 2011 | 06:55 PM
FUBAR55's Avatar
FUBAR55
You sure it's Torx and not an Allen plug?
Old Nov 8, 2011 | 06:58 PM
spankdog's Avatar
spankdog
Impact driver on a low setting
Old Nov 8, 2011 | 07:05 PM
Baeseman1's Avatar
Baeseman1
Yeah, that. Mine is an allen head, not a torx head.
Old Nov 8, 2011 | 07:31 PM
GREENOHAWK69's Avatar
GREENOHAWK69
I can use a Crescent wrench on mine, if need be to remove.
Old Nov 8, 2011 | 08:40 PM
Shovelhed's Avatar
Shovelhed
Did you say crescent wrench!? Seriously WTF lol
Old Nov 8, 2011 | 08:43 PM
Shovelhed's Avatar
Shovelhed
Why would you take it to somebody anyway? Do that maintenance **** yourself.
Old Nov 8, 2011 | 09:07 PM
nevil's Avatar
nevil
I don't remember any drain plugs that were torx. You sure you're looking at the right thing?
