2016 103 ho
Old Jun 3, 2023 | 01:50 PM
Donkeyskill's Avatar
Donkeyskill
Stage III
Default 2016 103 ho
Hello my bike has a popping sound when at operating temperature when idling and i slightly roll on throttle and let go of throttle ... is this a cause for concern or just the nature of the beast? I'm running stock exhaust factory tuner . Bike has 12,000 kms fresh spark plugs. Just came back from dealer full service .
Old Jun 3, 2023 | 02:51 PM
kel03's Avatar
kel03
Bring it back to the dealer, did they do something else other than fluids?
Old Jun 3, 2023 | 03:02 PM
Donkeyskill
Stage III
No a tire change sparkplugs just factory service it did it in the fall i dropped it off for warm winter storage full fluid change and lube as well as brake fluid flush wasn't so bad earlier in the cooler weather but at 80 degrees it pops ... not while driving or downshifting
Old Jun 3, 2023 | 03:06 PM
Donkeyskill
Stage III
could it have something to do with the longer lobe factory cams ? I read they are factory set real lean from manufacturer . If so will it damage engine ? should I look into a new tuner ? It has rushmore package from manufacturer.
Old Jun 4, 2023 | 02:26 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Depending on how fast you let off throttle. Your bike has throttle by electrical wire.
It's designed to prevent throttle like old bikes did with a cable by slamming shut the intake air and leaving a very rich fuel injection squirt with no air.
My guess in normal running down the road, it doesn't do it. Your tricking or basically doing something too quick for system to respond too .
Harley's stock exhaust is pretty free flowing with both mufflers tied together so each cylinder shares both and the previous charges help drag out the other since cylinders fire 180 from each .
(Probably more accurately said 360 since it's a 4 stroke but basically they don't fire at same time)
PS.
Welcome Robert.
Hope you enjoy your ride here.
Only as a suggestion, create a signature
line for your
bike, year, model, and all the
code letters.
You can add a bike photo to the signature too that you are using in your Avitar and it will display bigger.
And as a suggestion, make your next new post over in the new member welcome area to say hello. This original got moved my administration.
Old Jun 4, 2023 | 09:22 PM
hardheaded's Avatar
hardheaded
If it is 2016 make sure the ETMS is turned off. That's exactly what it does when activated. Drops down to the front cylinder when the air temps is above 80* and as soon as you touch the throttle the cylinder comes back in.
Bike has to be under something like 5 mph i think for it to work.
Owners manual or service manual will tell you all about it.
Old Jun 11, 2023 | 07:34 AM
V-Twins & Bowties's Avatar
V-Twins & Bowties
Confused , 180 apart firing of cylinders ?
What type of Harley is this ?
Old Jun 11, 2023 | 11:16 AM
todd-67's Avatar
todd-67
Gotta take Rips information with a grain of salt when he is hitting the bottle.
JonnyQuest
Milwaukee Eight (M8)
30
Apr 26, 2023 09:03 AM
TexasMotorcycleRider
77
Jul 21, 2021 10:40 AM
mesamark5
Jan 25, 2014 10:08 AM
RATFINK53
Dec 11, 2012 12:09 PM
nitro17
Jul 15, 2008 01:56 AM
