Anyone Have This Problem
Old Jun 4, 2023 | 08:32 PM
WRNGWY's Avatar
WRNGWY
Default Anyone Have This Problem
2009 Electra Glide Ultra Classic 96 inch twin cam motor
When I picked up the bike 2.5 years ago it would just go into that limp mode, dropping the rear cylinder, dead throttle,
check engine light on.
I replaced the throttle and the problem seemed to be solved. Then it started going into that limp mode again.
The shop I was dealing with (who closed last summer) went in and worked on the bike again. Said that the wiring
for the throttle was stretched and fixed the issue. This was like 2 years ago
On a Saturday May 20th of this year I stopped for the night in Oneida Tennessee.. Had gone up to Kentucky and was coming home
The bike was running great no issues mechanical wise going up or coming home
I stopped in Oneida Tennessee for the night and got up the next morning start the bike and as soon as I start it
the check engine light comes on and goes into that limp mode. Babied her all the way home with a few hiccups on the 3
hour ride home.
I have the bike in a shop where the guy works on Harleys out of his garage. He told me that his bike was doing the same thing
and he found that (like I said) the throttle wires were stretched and cracking. He also told me that there were 4 wires to that
throttle by wire set up.
I also read on a facebook forum a guy who posted was having the same problem on a 2010 Ultra Classic
If this is an ongoing problem why hasn't Harley corrected the issue with a recall or something
Has anyone had this problem?
Old Jun 4, 2023 | 08:38 PM
M Oclaf's Avatar
M Oclaf
Default Long past any expectations
Harley has no expectation or responsibility to address what at this point is a couple of decades old bikes experiencing a problem. That said, it appears yours is experiencing a repeat that you’re familiar with. Hopefully this time you get it fixed for longer time?
Old Jun 5, 2023 | 07:53 AM
WRNGWY's Avatar
WRNGWY
When it first started I freaked out. Had the throttle replaced and it started up again about a month later. I was headed out of state and north of Nashville on the I-24/65 it decided to do it when I was passing a semi and in the second lane. NOT GOOD
Had to trailer it back to the shop where I live and the wires were worked on and rearranged to another position rather than going under the air cleaner rerouted over the air cleaner and EFI and the connector behind the EFI was cleaned and that electric grease applied.
This was all 2 years ago.
I'm just wondering if this is an ongoing problem and has anyone else had this problem. I know Harley ain't gonna do anything
But there's always wishful thinking.
Old Jun 6, 2023 | 01:26 PM
memphisharley's Avatar
memphisharley
have you changed the wires and connector at the TB.
eBay item number:225116307398
Old Jun 6, 2023 | 03:07 PM
RANGER73's Avatar
RANGER73
I have allot of problems, but thankfully, that's not one of them.
That said, if you've addressed the wiring issue you might start looking into the sensor behind the Air cleaner.
Old Jun 6, 2023 | 03:57 PM
WRNGWY's Avatar
WRNGWY
I'll talk to the mechanic about it. I hate electrical. The shop I have it at said that it was throwing a bunch of codes. Hasn't thrown a code in 2 years.
He said a code was thrown for the 02 sensor/s and connectors. I'm guessing that would be the one behind the throttle body
That one was cleaned 2 years ago and did call and ask the mechanic about it. It's just down to tracking it down
See what gets me is this has been a problem when I first got the bike 2.5 years ago. And hasn't done this in 2 years. AND it had to pick when I was coming home from a road trip. When it gets out of the shop me and Elvira gonna have a talk about this. She probably won't listen tho
Old Oct 20, 2024 | 06:16 AM
stomp43@gmail.com's Avatar
stomp43@gmail.com
Stage II
Default Limp mode
Ended up being the connector to the throttle body.
15k on the bike.
I wired in a new connector and hard soldered it.
no problems in 3 years.
This is a common problem.
Old Oct 20, 2024 | 07:03 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Or not.
Old Oct 20, 2024 | 07:32 AM
Mongo1958's Avatar
Mongo1958
hour ride home.
What codes did you have?
I had a situation similar to yours. Riding home from work the engine sputtered and cut out.
The bike had several codes:
P1511: Power Management
P1514: ETC Airflow fault/Error
P2105: EFI Forced engine Shut down
P2135: TPS Correlation error
I have not resolve the issue yet.
Old Oct 20, 2024 | 07:39 AM
Mongo1958's Avatar
Mongo1958
Deleted
rwt
Dec 6, 2017 04:44 PM
Pat3
Jul 7, 2016 12:17 AM
jdvorchak
Jun 19, 2013 10:11 PM
harleydudeed
May 13, 2013 05:02 PM
hawkip50
Apr 19, 2012 05:31 AM
