Engine problem
Old Jul 5, 2023 | 03:12 AM
Erzsebet's Avatar
Erzsebet
Default Engine problem
Hi,
I have a 2008 heritage classic and it has got a problem.
After starting the bike when the engine is cold it starts immediately .
When the engine is warm and I want to start it again it is not working.
What could be a problem?
Thanks
Old Jul 5, 2023 | 05:17 AM
eighteight's Avatar
eighteight
Originally Posted by Erzsebet
Hi,
Thanks
Please clarify, when you attempt to start
!. The engine does not crank?
2. The engine cranks but does not start?
Old Jul 5, 2023 | 08:00 AM
Erzsebet's Avatar
Erzsebet
When the engine warm and I stop and I would like to restart the ignition is working but the bike does not run. I cannot go faster than 80 miles/h with it. After 20 mins when the engine has been cooled it start running again.
Old Jul 5, 2023 | 08:18 AM
eighteight's Avatar
eighteight
Has it thrown any fault codes ?
Cam or crank position codes ?
Next time it won`t start:
Check for spark
If no spark the plugs will be "wet"
If it has spark , you have to check for a fuel delivery problem
I suspect a heat related spark problem
Old Jul 5, 2023 | 09:02 AM
Erzsebet's Avatar
Erzsebet
Thanks for the answer. I have alread checked and it has got spark. I have to check fuel delivery system.
Old Jul 6, 2023 | 11:44 AM
nevil's Avatar
nevil
Look at the condition of the hoses and fuel regulator in the tank. It is common for the lines to get tiny holes, so if you prime the pump you might be able to see or hear gas hitting the inside of the tank.
Old Jul 6, 2023 | 12:43 PM
Erzsebet's Avatar
Erzsebet
Thanks for the advice.
Old Jul 6, 2023 | 12:45 PM
eighteight's Avatar
eighteight
Certainly common but I`m not sure why it would be heat related.
Old Jul 11, 2023 | 12:56 PM
cycleman11's Avatar
cycleman11
The symptoms sound like a coil problem. Runs bad when hot or quits, won start and when allowed to sit for a bit and cool down, starts and runs good and then does the same thing over and over.
Another issue I had on my 08 Heritage was the battery had a bad cell. It would start good, then if I stopped for gas or something similar, push the button nothing happened. It was an intermittent thing and I was never really sure if it would start. This happened when I was in California on a trip, so I had a local HD dealer do a load test on the battery. Sure enough, it had a bad cell. Replaced the battery and no more problems.
Old Jul 11, 2023 | 12:58 PM
M Oclaf's Avatar
M Oclaf
Default Trade it in
Lots of great deals at HD…
KennyLof
Jul 30, 2022 05:01 AM
VDeuce
Milwaukee Eight (M8)
Feb 26, 2018 02:31 PM
sphoad
Jul 8, 2009 05:50 PM
pdexter
Mar 13, 2008 03:22 PM
ardmorejoe23x
Jul 10, 2006 12:05 AM
