Head gasket
Old Jul 15, 2023 | 09:34 AM
Kycrow's Avatar
Kycrow
Stage I
Default Head gasket
I have a 2005 88” that I’m having bored to a 95, I’m using wiseco forged 9.5 to 1 tracker pistons with the fueling 543 cams. My heads are being milled slightly to smooth out the mating surface. What thickness gasket should I use to get 10 to 1 compression or slightly higher without compression releases.
Old Jul 15, 2023 | 09:48 AM
470004's Avatar
470004
Cometic's MLS gaskets; https://www.cometic.com/applications/v-twin
Old Jul 15, 2023 | 09:54 AM
Ohio HD's Avatar
Ohio HD
To make 10:1 you need to do the following.
Set the pistons to a zero deck height in the cylinders
Use a 0.030" head gasket
Have the head gasket surface milled until you have a 78cc combustion chamber
Added: This is assuming these pistons are flat top.
Old Jul 15, 2023 | 08:03 PM
Max Headflow's Avatar
Max Headflow
Yeah. So in that case, you'll need to mill about 0.056 inches off the heads. Assuming heads are 86ccs.
Only need to mill about 0.035 off if you go to 98 ci.. 3.938 bore.
Old Jul 16, 2023 | 07:38 AM
PureHybrid's Avatar
PureHybrid
Is a dome piston not avaliable?
Old Jul 16, 2023 | 08:56 AM
Rounders's Avatar
Rounders
The most common size I see is .030, from Harley and cometic. James makes a .35, but since you want to 10, I am guess you want .03. Email cometic or one of the other companies you are working with
Funny how .030 has become common. I believe stock is .043 or .045. Going thinner was seen as crazy by some back then.
Old Jul 19, 2023 | 08:45 AM
eighteight's Avatar
eighteight
CP Carillo offers several
Old Jul 19, 2023 | 09:30 AM
Max Headflow
So does KB.
Old Jul 24, 2023 | 09:02 PM
60Gunner's Avatar
60Gunner
Why is that? It's not just a compression thing. Stock is what it is because of the variance in how far in the hole the pistons are and the size of the chambers from one engine to the next and deemed "safe"
A tighter squish is beneficial. .030 to .035 is ideal. Some have done and they sell a .027.
Old Jul 24, 2023 | 09:11 PM
Max Headflow
Thinner than what? 0.030? or 0.045?
When was "then"
QNman
Engine Mechanical Topics
Aug 22, 2017 11:35 AM
SportbikeCO
16
Mar 6, 2017 09:44 AM
rg567
Jan 21, 2014 10:27 AM
steve303sg
Sep 1, 2013 02:18 AM
cjlandry
Exhaust System Topics
Jun 5, 2011 07:10 PM
