Milwaukee 8 Engine Problems
Old Aug 22, 2023 | 01:51 AM
Fattyonafatboy's Avatar
Fattyonafatboy
Stage I
Default Milwaukee 8 Engine Problems
Hi everyone, I am well aware that the early M8 engines from 2018 - 2020 had their fair share of mechanical issues. Am in right in thinking that the problems have been ironed out in the 2023 models? I currently have a 2015 twin cam and am think of upgrading to a new fatboy but I keep hearing things like “stick with your twin cam… new M8’s are nothing but trouble…” Are they right? I am interested to hear from anyone that has one and whether they’ve had a good or bad experience with it
Old Aug 22, 2023 | 03:29 AM
sjoko's Avatar
sjoko
....depends how you look at it ,....the best thing what you can do , is changing the stock oil pump for an S&S oil pump + camplate ( and that counts even for the newest M8 )
That is the best solution in case you ride the bike constantly to his limits for very long periods of time .
In the beginning I was furious due to a stupid salesman ( at a lausy HD-dealer ) , who told me in 2019 that all "issues" were solved .( in fact the "oil transfer issue" and also wrong disc brake floaters )
But that stupid ******* was lying to me , or he was just incompetent for his job.
( no surpise that I've chosen to visit another ( and very fine ) HD-dealer from that time )
Well , ...later on , that "oil transfer issue" turned out to be a minor problem , what could be solved by removing a silly nylon oil reflector ring and also by mounting a tiny rubber vent in the inner primary cover.
Today , that tiny rubber vent is stock in all new M8 engines.
Another issue is , that carbon deposits can be build up on the pistons , on acount of the crank case ventilation . ( but that is something you can blame on the EPA restrictions / laws in your country )
Today I can tell you , this is my very best motorcycle of all I've ever had ,...but to be honest ,...it has a lot of ( S&S ) aftermarket parts in it now ,... some are necessary , and some are not )
Old Aug 22, 2023 | 07:25 AM
cobra23's Avatar
cobra23
I have a 22 street bob and a 23 road king special. No problems with either one after 9000 combined miles, other than the untrustworthy, expensive local dealer. In my opinion, the M8 is the best motor harley has come out with to date, although it did have some early growing pains that should have been addressed before the bikes went on sale.
Of course, there are plenty of areas that could be improved like the seat, suspension, external breathing, exhaust sound, performance etc.
Old Aug 22, 2023 | 07:27 AM
strych9's Avatar
strych9
Welcome to HD forums!
Old Aug 22, 2023 | 10:35 AM
Old New Rider's Avatar
Old New Rider
They were ironed out after 2020. I have a 2021 M8 107 Heritage Classic. No issues at all.
Old Aug 22, 2023 | 10:52 AM
FLASH1970's Avatar
FLASH1970
Old Aug 22, 2023 | 11:47 AM
TriGeezer's Avatar
TriGeezer
There were no systemic issues with the early M8 motors. A few had sumping, fixed by the latest oil pump. A few had granny to primary transfer, fixed with primary vent.
Many put 1,000s of trouble free miles on their M8s including me.
Old Aug 22, 2023 | 11:50 AM
smitty901's Avatar
smitty901
Yes a few issue cam up. Early was the transfer from Trans to primary fixed. The the sumpping two different causes one was in assembly the other was oil pump both fix. The M8 is leaps and bounds better than the TC. I have owned several of both.
TC 103 even back to the TC96 are good. M8 is better.
Old Aug 23, 2023 | 01:13 AM
sjoko's Avatar
sjoko
History repeats itself over and over again ,....as soon as Harley-Davidson comes out with something new on the market , we have to deal with ( minor ) design flaws.
( .....and the aftermarket takes advantage of it )
Aren't we all used to that by now ?
Old Aug 23, 2023 | 11:00 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
There is no need to spend money on an aftermarket cam plate and oil pump, the latest oil pump is all that is needed on an early M8, and many will say even that is not needed if the bike has no sumping issue.
