Lost key fob
Old Dec 17, 2023 | 01:30 PM
Joe1980's Avatar
Joe1980
6th Gear
The bike only has one key fob. Hell I don’t the the guy I bought it from gave me the code. I have tried the last 5 of the vin, also have tried all 1-9 no dice. The guy I bout it from must has gotten a new phone cause his number doesn’t work anymore. That going to be a lot of number it try.
Old Dec 17, 2023 | 01:34 PM
Rounders's Avatar
Rounders
Are you stuck on the rode or just trying to start bike?
I suspect calling a dealer in the morning, regardless will be your avenue to pursue. Maybe try some simple numbers or maybe there are common numbers,
I am thinking of the cops who help load up the burglars van.
Old Dec 17, 2023 | 01:39 PM
WP50's Avatar
WP50
Originally Posted by Joe1980
Hell I don’t the the guy I bought it from gave me the code. .
You got the code???
This may end up hurting if you have to get it in some where.
What part of Oklahoma are you in?
Do you know where it was bought new?
Try to stick with one single thread for info. Just better in the long run Sir
WP
Old Dec 17, 2023 | 01:43 PM
Rounders's Avatar
Rounders
Watched youtube video from LAB telling you to change it cause harley only uses a handful of numbers, thought that was older bikes.
Old Dec 17, 2023 | 01:52 PM
booyajj's Avatar
booyajj
You have to have a working key fob or know the current security PIN to change it.
Old Dec 17, 2023 | 01:54 PM
Rounders's Avatar
Rounders
Again this was older bikes, but they claimed harley only used a few PINs, so you should change it.
Old Dec 17, 2023 | 03:12 PM
CoolBreeze3646's Avatar
CoolBreeze3646
1. Do you have the bikes title in your name?
2. If yes, then trailer it to a dealer with your title in hand and have them access the PIN and order you a new FOB that will need to coded by them.
3. Posts like this from a newer person are always suspect as the bike may be stolen and the poster just trying to find out how to get around the security system.
4. May want to look a little harder and try and find your FOB, then you can set your PIN.
Good Luck & Best Regards.
Old Dec 17, 2023 | 05:48 PM
Vec's Avatar
Vec
Your Pin # is OU812..
your welcome
Old Dec 17, 2023 | 06:06 PM
Joe1980's Avatar
Joe1980
6th Gear
I am going to get it fix tomorrow there is a guy says he can get the pin out with his computer system Then program a new code for me also
Old Dec 17, 2023 | 06:10 PM
kel03's Avatar
kel03
Keep us posted.
