No Good Mechanics
Old Sep 9, 2024 | 08:22 AM
npn's Avatar
npn
A lot has been said already. I guess at the end of the day, if I want the bike to perform at 100% I need to spend the time and do it myself. I think I'm at like 95% and I'm OK with that
My biggest problem is that I can only do so much by watching videos and reading posts from others. No offense to anyone but a good mechanic imo will not spend time here...
Old Jan 30, 2025 | 02:52 PM
npn's Avatar
npn
Another example, different dealer too: https://www.hdforums.com/forum/2014-...l#post21931193
What do the charge, $300 an hour? Hell, for one third of that I'd work on people's bike. But I can't do it - I'm only responsible for my bikes.
Old Jan 31, 2025 | 04:44 AM
Kenny94945's Avatar
Kenny94945
I can relate to the OP writing... no good mechanics.
Carb tuning is an art... float height, needle size, jets, air fuel.
At shop labor rates, this can get expensive.
If (if) the OP desires only an air/fuel screw adjustment... gosh, maybe the best is to experiment DIY, 1/4 turn here and there, with spark plug chops/ plug readings.
The other steps, jets, needles, and all, perhaps research to get in the ballpark.
I understand the OP did DIY rebuild their carbs, so the OP has talent.
Chicago area; I have no mechanic referrals.
Good luck, again I can commiserate.
Old Jan 31, 2025 | 05:19 AM
702's Avatar
702
There are many good mechanics here on this forum. But here's the deal -- someone posts they have an issue and ask for help, so a couple of good mechanics try and help, and they respond with some very good advice. Then you have 2 or 3 complete fukking idiots start jumping in and wrecking the thread causing the good mechanics to stop responding. I haven't been here very long but I've seen some very good guys come and go, and yet they let a few shitbags have the run of the house. You don't have to be a professional mechanic to be a good mechanic. There are tons of super good and smart guys in their home garage working on bikes/cars/whatever because they are passionate about their hobby. They're here, but why bother because the way this place is run doesn't favor us helping each other.
Old Jan 31, 2025 | 07:22 AM
npn's Avatar
npn
You saw my post about the Legend suspension install, right? https://www.hdforums.com/forum/2014-...l#post21931193
Old Jan 31, 2025 | 07:34 AM
702's Avatar
702
If you're talking to me, yes I did. I do all of my own work to avoid those issues.
Old Jan 31, 2025 | 07:51 AM
Rogue1's Avatar
Rogue1
True fact. I love the guys that chime in and say "I don't have your particular problem, I don't even have your model bike but here's what I would do".
Old Jan 31, 2025 | 08:46 AM
Rains2much's Avatar
Rains2much
I read a few posts but not all… didn’t see anyone comment on why the pipes would cause you trouble.
I’m a huge fan of drag pipes. But they just simply are not the right pipe for every bike. If your bike is stock, drag pipes will likely never run right. Drag pipes are made for big compression big cams big carburetors and lots of air movement.
also, we don’t know what style of drag pipes. These are like those LA pipes that are cut off by the nose cone that Bike will never run right. A good rule of thumb is they should be between 34 and 36 inches long. They should also be of equal length. You will likely need some thumbscrews or the DK TTI units at the end of each pipe.
once you’ve done all of those things, it still may have a stumble in some RPMs. Big motors that make a lot of power make drag pipes sing. I have absolutely zero stumble with a carburetor on any of my bikes. They are smooth through the throttle with open drag pipes. But that’s because they’re all Strokers, they’re all high compression, they all have big cams, and I don’t live at 2000 RPM.
Maybe you have a carb problem, but more than likely you have an exhaust problem. Why not post a pic of your pipes and carb. We can probably point you in the right direction.
Old Feb 1, 2025 | 12:11 PM
Hathaway's Avatar
Hathaway
Upon reconsideration of your original post, I think you need to learn to do it yourself. More work maybe, but you'll be happier with the result.
Old Feb 1, 2025 | 01:15 PM
npn's Avatar
npn
I moved on to other "problems", like changing the front suspension on my own but what I found in the fork, done by the dealer, made me recall this thread.
I appreciate you reading the thread from the beginning, gents. I did end up fiddling with the carburetor and got it dialed in to my satisfaction.
