idle/ throttle control cables
Old Sep 5, 2007 | 01:07 AM
TalkLikeAPirate's Avatar
TalkLikeAPirate
Default idle/ throttle control cables
hi all...i just replaced my stock switch housings to chrome tonight. got it all back together and seams to work fine. i was wondering if there is some way i am supose to adjust my idle/throttle control cables. The throttle springs back fine. What does the idle one do and how should it be? if anything......
Old Sep 5, 2007 | 06:24 AM
Uncle Scrooge's Avatar
Uncle Scrooge
Default RE: idle/ throttle control cables
I just use the adjusting nut to take the slack out of the throttle cable, then do the same with the idle cable. It's always worked just fine. By the way, be sure the little plastic piece that applies pressure from the "manual cruise control" thumbscrew is properly positioned. If it's gotten a little out of position it will cause the throttle spring return to drag some.
Old Sep 5, 2007 | 07:54 AM
TalkLikeAPirate
thanks geeze..thats what i did ,(slack). throttle snaps back good so i figure the adjusting shoe must be in the right place also. I was worried that the adjustment effected the amount of throttle i was able to give it and the engine idle speed.
DrRude
Sep 4, 2014 03:47 PM
jamess71
Mar 21, 2014 02:37 PM
huey408
Feb 18, 2011 04:46 AM
STARRY
Jun 1, 2010 08:00 AM
cerelious
Jan 10, 2010 06:28 AM
