General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
I get that, however this is a temporary solution. Next year well be getting a place up north for summers - once we lock down this new house with impact windows, doors, and a roll down shutter over the glass doors on the lanai (or porch for you non-Florida people). So It will be a waste of money at that point.
If it's quite temporary, why not an anchor or two in the wall and a couple of ratchet straps? I bet you have the latter laying around, and the former might cost $10-20.
Until April/May most likely. But do you mean use the straps to pull the bike upright against the wall??
Yes, this is what I was thinking. Obviously not as secure as the dolly solution, but your original post mentioned thrift and you later mention the fact that it's a very temporary solution. So long as the bike is fairly upright, there's not a lot of gravitational force to pull against the anchors. If it's in gear, you don't have to worry about movement along that axis. It should work, although you may not want to put anchors into the wall that you may then have to patch later.
Yeah I get it. I don't have a problem spending, I just don't like wasting. And I'll just end up having to sell anything I get in 3/4 of a year anyway. (or toss it as has happened before...) Your idea would work, but I don't think I'd choose it over a cheap HF dolly and a chock (if I can make it work).
Decided on a different direction. A self storage place about 5 min from me has 10x10 drive up storage rooms for $50/mo. Since we have stuff from the old house we decided its easier to keep the dyna there, instead of cramming it into the already tight garage.
