Hand control reverse compatability?
Old Dec 12, 2025 | 04:14 PM
owenewowen's Avatar
owenewowen
Default Hand control reverse compatability?
I've got 95 and down hand controls with an 11/16" MC (dual disc) front end. I just saw someone selling a 96+ 11/16" MC and am wondering if this newer MC and lever would fit with my older style switches? My bars are internally wired so I don't want to pull them out but the old style MC is huge and takes up a lot of space visually. Any insights would be greatly appreciated.
Old Dec 14, 2025 | 07:53 AM
bustert's Avatar
bustert
this is where a walk though a fiche would help
there are online fiche like ronnie and others
Old Dec 15, 2025 | 09:10 PM
Bass-M's Avatar
Bass-M
Yes, it can work. The 96+ master and lever will bolt onto your 95 bars and function with your dual disc. The main issue is your old switches won't physically bolt onto the new lever perch. The switch mounting is different between those years. You'd either need to swap to 96+ switches (requiring bar re-wiring) or use an aftermarket switch kit that clamps to the bar separately. So, you can't directly keep your old switches on the new MC assembly.
Caz2112
Mar 12, 2025 06:03 PM
Mullitt
Sep 8, 2021 05:35 PM
Sparks200
2014-2024 Touring Models
Sep 21, 2017 08:40 AM
shawkpilot
May 20, 2013 07:54 AM
SSMNightTrain
Jun 23, 2012 07:41 AM
