Stupid simple mirror nut question
Old Mar 10, 2026 | 12:56 PM
TeeJayEe's Avatar
TeeJayEe
Default Stupid simple mirror nut question
Can't believe I'm asking a question about mirror nuts but does anyone know the part no. for the longer OEM acorn nuts? I just got a replacement set of short-stem mirrors for my 23 Heritage and the acorn nuts they came with are too short. The fiche says 7331 but not sure if that's the short or long one.
I know I could add a stack of washers or a 5/16" nut but I want to keep it stock and here in the UK we don't have many hardware stores I can just walk into and find similar from.
Thanks!
Old Mar 10, 2026 | 01:17 PM
WP50's Avatar
WP50
Maybe a chrome spacer
Maybe a pic of the mirrors or a link to them could help someone here to help you.
http://www.bing.com/search?q=chrome+...tsg=1&hsmssg=0
good luck WP
Old Mar 10, 2026 | 02:53 PM
TeeJayEe's Avatar
TeeJayEe
Thanks yeah they’re just the standard HD short stem mirrors, sold in a pair.
I must have missed the mirrors when cleaning the bike this Winter as mine got pitted and the nuts rusted, so I replaced them.
The mirrors are identical but the acorn nut is about 1/2” shorter with the new pair than the one that came with the bike so I’m looking for the p/n for the longer nut.
Old Mar 10, 2026 | 05:25 PM
WP50's Avatar
WP50
I did go look for ya but I couldn't decide if the one I looked at was longer or the short. as you mentioned
Good luck Sir WP
I might have misunderstood but does this look right
https://www.ebay.com/p/9027448613
Old Mar 10, 2026 | 05:30 PM
TeeJayEe's Avatar
TeeJayEe
Good luck Sir WP
Thanks. I’ve ordered the 7331, only one way to find out if they’re the right length…
Failing that I’ll just grind the excess threads off and use the shorter nuts that came with the new mirrors.
Old Mar 11, 2026 | 09:07 AM
MarlinSpike's Avatar
MarlinSpike
Veteran: Coast Guard
Different year bike. So this is just for info in case it helps your situation if the one you ordered does not work out.
But I just did a mod that took the blinkers off the bars control mounts. The left side had an adaptor for the blinker / mirror mount and no acorn nut for that side as the blinker went on the fitting.
I bought a 5/16" x 24T acorn nut at our hardware store. Very, very close to the OEM acorn in appearance of the right-side mirror stem. I had to trim a slight 1/8" to a 1/4" off the left side mirror stalk threads so the nut does not bottom.
Easy fix. Looks factory and was $2.
Old Mar 11, 2026 | 03:50 PM
TeeJayEe's Avatar
TeeJayEe
Nice, thanks. I reckon this is exactly what I’m gonna need to do.
Old Mar 11, 2026 | 06:22 PM
chopper_man's Avatar
chopper_man
Did the mirrors not come with small chrome spacer rings? They either raise the stem a bit higher or they go on the bottom to take up the space to allow the acorn to fit properly.
Old Mar 12, 2026 | 09:24 AM
TeeJayEe's Avatar
TeeJayEe
Unfortunately not. Just the acorn nut and toothed washer. Genuine part too, ordered direct from HD!
Time to get the grinder out I reckon. 1/2" off the stem thread and it's sorted.
Old Mar 12, 2026 | 09:30 AM
M18A1's Avatar
M18A1
I would love to find some of those little chrome spcer rings that go on the mirror stalk as I lost one on one bike and had to steal from my "project" bike to replce it. Trei ebay and the dealer...No Luck
camden
Jul 23, 2012 08:32 PM
brandon78
General Topics/Tech Tips
Aug 2, 2010 01:47 PM
brandon78
Jul 30, 2010 01:33 PM
lhcstreetbob
Nov 4, 2009 10:50 AM
OhioSkully
Dec 25, 2008 10:29 PM
