won't start
Old Jan 2, 2006 | 11:17 AM
littledevil's Avatar
littledevil
6th Gear
Default won't start
Sorry if I may have a dumb question but Harley's are new to me. I just received a 06 883C for my birthday, put about 11 miles on it and now it won't start. It tries to crank over but nothing happens. Last ride it was missing and back firing, help.
Old Jan 2, 2006 | 11:25 AM
Grover's Avatar
Grover
Administrator Emeritus
Default RE: won't start
Call HOG and have it towed to your dealer. There are mechanics there that can help with that problem.
Old Jan 2, 2006 | 12:19 PM
littledevil
6th Gear
According to DVD I received I will get signed up for HOG for the first year. How or when will I get my membership number or do I need to sign up?
Old Jan 2, 2006 | 12:25 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Michelle,
It will take about 4 to 6 weeks to get your membership card. One quick check before you take your bike back. On the right handlebar control there is a kill switch. Make sure it is in the "run" position. Some people use it to turn off the bike and forget about it. I never use mine and if it accidently gets pushed I work myself up to a tizzy trying to find out why my bike won't start before I realize what's wrong. Your bike is under warranty so you have no worries. Just call the dealer (if my fix doesn't work) and set up a time to have them check it.
Also, Welcome to the forum, did you post on the New Members Forum?
[sm=biker2.gif]
Old Jan 2, 2006 | 12:31 PM
littledevil
6th Gear
Thanks alot for the suggestion, I tried that all good there. I'll just have to wait and have them check it out. Just a little frustrated, having to take the bike in again within two weeks. First time to replace cracked speedometer and now this. Plus its in the upper 70s here in Texas and I would like to ride.
Old Jan 2, 2006 | 12:42 PM
HDF Tech's Avatar
HDF Tech
Did the problem start on your last ride and after you got fuel? Also don't over choke it or you'll flood the engine. Did you use the choke, just trying to throw out some suggestions here.
If so suspect the fuel has some water in it which the dealer will probably charge you for to fix.
Old Jan 2, 2006 | 01:17 PM
littledevil
6th Gear
I actually have only been able to put 11 miles on, it has the fuel taht they put in when I picked up the bike
Old Jan 3, 2006 | 11:22 AM
taurusjim's Avatar
taurusjim
If you ran the 11 miles with the choke on or partially on; check the plugs for fowling. Clean, regap, and replace,.... I know this may sound stupid, but how much gas is in it. Is the gas valve on reserve, or on, or off....check the stubid things first, than right back to dealer. ok let us know what happened. don't be shy everybody makes silly mistakes.....good luck
Old Jan 3, 2006 | 08:44 PM
littledevil
6th Gear
I appreciate all the suggestions, I took the bike in today. Tomorrow I will find out what happened.
Old Jan 3, 2006 | 09:10 PM
Grover's Avatar
Grover
Keep us posted as to what you find out. Good luck with the dealer - hope every thing comes out OK and is under warranty.
08streetglyder
Sep 19, 2016 09:10 PM
Slamed Slim
Dec 31, 2014 09:22 PM
king124
Jul 13, 2014 03:58 PM
bpd138
2014-2024 Touring Models
May 15, 2014 12:48 PM
firemeat
May 10, 2013 11:51 PM
