Cruise control disengagement
Old Feb 3, 2006 | 02:13 AM
iine's Avatar
iine
2nd Gear
Default Cruise control disengagement
I started having trouble with cruise disengagement today. At first I thought it was the wind blowing my throttle rocker but still had the problem even after I removed it. I ran the code check routine and sure enough throttle roll off is the culprit. Do I just need to readjust my cables and do the lash init to solve the problem?
Old Feb 21, 2006 | 09:39 PM
oneton's Avatar
oneton
5th Gear
Default RE: Cruise control disengagement
that is the most likely thing to ck adjust as in manual then take for a ride leave lock not just finger tight can stop and turn 1/4 turn at a time and retest p.s. bring tools to tighten with you hope this helps, oneton
Old Mar 5, 2006 | 02:28 PM
iine's Avatar
iine
2nd Gear
Update - I finally took the time to go through the throttle and idle cable adjustment procedure followed by rinitializing the cruise control per service manual and everything seems OK now. I think my throttle roll off adjustment was too sensitive.
mrfikser
Apr 5, 2011 07:34 AM
chl11
Oct 11, 2008 11:47 PM
Streetrunner
Feb 17, 2008 03:22 AM
Herr Monk
Oct 19, 2007 11:41 AM
iclick
Dec 11, 2006 12:18 AM
