spitting and sputtering
Old Apr 13, 2008 | 02:42 PM
87883sportster's Avatar
87883sportster
Stage I
Default spitting and sputtering
I'm a newbie rider and I have a problem with my 97 883 sportster XLH I just purchased 2 weeks ago. After riding for about 15 - 20, it still won't run with the choke all the way in. I replaced the spark plugs which were black and that helped a little but did not fix the problem. Mods are Vance & Hines drag pipes, Screamin Eagle wires and coil (not sure how old the wires and coil are). Carb is also jetted. bike has 18k miles. Thanks in advance for your help!
Old Apr 13, 2008 | 03:42 PM
t150vej's Avatar
t150vej
Default RE: spitting and sputtering
4 things would be common problems by the symptoms you described;
1. Loose main jet or holder (check idle jet too)
2. bad float adjustment or needle valve
3. Bad accelerator pumpcheck valve(or pump diaphram itself) letting fuel constantly feed through the squiter jet.
4. Hole in throttle slide diaphram
One more thing - not common - the choke valve inside the carb (not the cable) could be sticking and not shutting all the way. That would flood the engine and keep vacuum the port open enough to cause a major leak at the same time. First CV I ever touched had that prob and it about drove me nuts since I had no knowledge of that type carb.
Whatever it is, doesn't sound like anything major and doubtful it's the ignition. Good luck
Old Apr 17, 2008 | 11:05 AM
Airywhisler's Avatar
Airywhisler
Sound like the choke valve, time to rebuild the carbs
Acchase
Jan 31, 2017 01:46 PM
whitewallpaul
Mar 31, 2013 11:29 AM
Vdoubleyou
Jul 6, 2012 09:28 PM
kenward
Apr 20, 2009 05:09 PM
rj93/4fun
Exhaust System Topics
Jan 12, 2009 11:05 PM
