removeing foam tape
Old Mar 28, 2005 | 03:30 AM
Clammy's Avatar
Clammy
Default RE: removeing foam tape
When I used to work as a mechanic at a GM dealership, we used Acrysol (also known as Acry-solv) to remove adhesive, and general crud from body panels. No matter how much we used, it never damaged the finish.
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
Old Mar 28, 2005 | 12:13 PM
hawk's Avatar
hawk
OH MY GAWWD
ORIGINAL: nmfxstc
Or...ya getchya a weed burner or large blowtorch and, well....you know....
Old Mar 29, 2005 | 04:52 PM
paul5150's Avatar
paul5150
6th Gear
Thanks to all. I used goof off and bug and tar remover. And elbow grease.
Old Nov 2, 2005 | 06:11 PM
ultravista's Avatar
ultravista
My vote is for GOOF-OFF too. I removed the same panels on my Softail. Worked like a charm.
Old Nov 5, 2005 | 07:44 PM
Taildraggerdave's Avatar
Taildraggerdave
Good lookin paint job! I use dental floss to cut the reflector off and rubbing alcohol to remove the glue--although this photo doesn't show it.
Old Dec 17, 2005 | 12:51 AM
usblues101's Avatar
usblues101
Some good idea's above,most dealers use lighter fluid,then laquer thinner if needed.Dot 3&4 brake fluid eats paint,Dot 5 is silicone-based and doesnt,good luck,Bob
jeshifle
May 27, 2013 11:02 PM
micahpop
Detailing
13
Jun 24, 2010 11:46 PM
BrentsterS
Jul 4, 2009 12:30 PM
Crazie
Jul 24, 2007 10:16 AM
jarman
Oct 25, 2006 09:12 PM
