Right Grip replacement- Help
Old Apr 21, 2006 | 10:13 PM
chipper914's Avatar
chipper914
1st Gear
Default Right Grip replacement- Help
So I purchased some new grips for My 2006 Road King- followed the instructions and got the left one done/ No problems.
Then I read on to start the right one and -oops it says to refer to the service manual. Why they dodn't give me all the instructions- I don't know, but I don't want to buy the mannual right now just to finish the job. Any one have this section they can send me on a PDF or some feedback. I hate to bring it in if it's simple..
Signed,, My Grips Dont match now (Chip)
Old Apr 21, 2006 | 11:24 PM
liltrk's Avatar
liltrk
Default RE: Right Grip replacement- Help
Check the DIY section under chrome switch housings. There is a section all about grips.
Old Apr 22, 2006 | 05:43 AM
Rhubarb's Avatar
Rhubarb
Be sure to read the last part about a washer in the brake lever.
Most important part of the job. Right up there with a towel under the bars to catch the ferrules if you drop them.
Old Apr 24, 2006 | 09:40 AM
rh8234's Avatar
rh8234
You're going to run into the same problem "refer to service manual" with nearly every item you buy for the bike. Do yourself a huge favor and do get the manual. It will pay for itself many times over. Also get the parts manual. It has very useful diagrams of every part of the bike and gives you all the original HD part numbers.
Old Apr 24, 2006 | 02:06 PM
JamieCarr's Avatar
JamieCarr
I changed my grips and never looked at the manual. On the right side, it will help if you have some vice grips w/ the needle nose. You will have to lock down the throttle cable to keep it in it's track, just go slow, and note the exact position of everything when you open it up. It's a little bit of a pain, and might to have another set of hands. Don't worry about the lever assy, until last. Pay attention mostly to the way the cable fits in the groove for the throttle(plastic parts, so be careful not to break). Don't be afraid to open it up though, I'm not a very good mechanic, and I managed to get my grips on in about an hour. If I can do it, anyone can really.
[IMG]local://upfiles/11242/C7F37BFB1C3E49328831DBC0EC58C0D9.jpg[/IMG]
Old Apr 24, 2006 | 02:34 PM
Angry_Monkey's Avatar
Angry_Monkey
Hemostats work the best for holding the cables for you fisherman/at home surgeons..
Old Apr 24, 2006 | 03:14 PM
oldgeezer's Avatar
oldgeezer
If you will loosen both throttle cables at the adjusting nuts right under the grips, installation is a snap.... unless you lose the brass ferrule.
Old Apr 25, 2006 | 11:50 AM
hd_sob's Avatar
hd_sob
ORIGINAL: liltrk
Can someone please post a link to this? I am unable to locate the thread...THANKS!
<edit> NEVERMIND: https://www.hdforums.com/m_217399/tm.htm
TOFTS
2014-2024 Touring Models
Jan 24, 2016 06:43 PM
blackpullet
Mar 17, 2011 06:24 AM
simpkinst
Mar 2, 2010 06:32 PM
first dyna 07
Aug 3, 2007 02:25 PM
cajunman831
Jun 30, 2006 09:38 PM
