Help!!! Release compression and hardstarting
Old Feb 23, 2009 | 03:06 AM
deathrattleshake's Avatar
deathrattleshake
Stage III
Default Help!!! Release compression and hardstarting
greetings gentlemen!!!i'm trying to figure out the cause of hardstarting and release compression of my '97HD heritage softtail...what should i check first?i hope someone can help me with this slight of a problem...thanks!!!!
Old Feb 23, 2009 | 07:52 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
What is your build on the engine or is it stock?
Old Feb 24, 2009 | 02:20 AM
deathrattleshake
Stage III
Default release compression and hardstarting
actually the engine is still stock...im at a lost here... hehehehehe...thanks brothers!!!
Old Feb 24, 2009 | 08:27 AM
KBFXDLI's Avatar
KBFXDLI
Ok, stock motor...why do you think it is a compression issue? If it is hard starting the first thing I would check is your battery. If it is old and weak like me it will not give you the voltage necessary and will cause the starter to groan as it tries to roll the motor over. Charge it first as see if that helps. If it doesn't then remove the battery and take it to a shop and have it load tested. Just make sure to pull your maxi fuse before you remove the battery.
Old Feb 24, 2009 | 03:12 PM
rmc115's Avatar
rmc115
battery cables corrode inside too, cheap to replace. no maxi fuse on a 97. mike
Old Feb 25, 2009 | 01:02 AM
deathrattleshake
Stage III
thank you brothers for your help...
actually here's why i think my bike's releasing compression...
everytime i turn the ignition and the "kill switch" on then turn them off again then turn them on again, the bike releases compression... it's weird really....
i'm really trying to figure the problem out...
any help will be greatly appreciated...
THANKS!!!
LIFE'S SHORT... RIDE HARD!!!
Old Feb 26, 2009 | 08:26 AM
robzuc97's Avatar
robzuc97
No idea: compression is not an "electrical" symptom so that really would be weird! My
'97 FLSTC is somewhat "cold-blooded" ever since I bought new but improved after disassembling/cleaning carb and proper jetting. First to check is the battery terminal and connections: takes more current to jump a loose connection then a tigh one.
Old Feb 26, 2009 | 10:33 AM
KBFXDLI's Avatar
KBFXDLI
THANKS!!!
If you are not rolling the starter over that is impossible. If you are rolling the starter then you probably don't have enough voltage. The only way it could release compression is if your engine has an S&S electric compression release on it. Does it have that?
Scooter Pieman
Jan 12, 2018 05:21 PM
KingCripps
Sep 22, 2014 12:09 AM
steelman
Feb 12, 2013 10:15 PM
cccbebad
Aug 25, 2008 05:01 PM
Tanker2
Apr 23, 2008 02:17 PM
