Starting troubles....???
Old Aug 25, 2008 | 01:14 PM
cccbebad's Avatar
cccbebad
Default Starting troubles....???
Ok I have built a pretty stout 95" motor, well lately I have been having a little trouble starting... as if my battery is dead, it clicks clicks clicks and then turns over, but my battery is brand new and I charge it once a week. Or actually "tend" it! I was wondering if the compression was to much and I just needed a bigger starter or something like that?? Please help??
Old Aug 25, 2008 | 03:18 PM
rounder's Avatar
rounder
any chance the battery cables loose or the ground is touching paint and not the best it could be where it meets the engine.
Old Aug 25, 2008 | 04:46 PM
Sumo's Avatar
Sumo
yep, sounds like the battery not maintaining its voltage under load.
But the Denso starter on the bikes will also just click when the soleniod contacts are just about worn out, i assume your 2005 model bike hasnt done that much starting?
Old Aug 25, 2008 | 05:01 PM
dyna rider's Avatar
dyna rider
Default Hard Starter
The higher compression bikes are harder to start especially when they are hot. Do you have the extra hole in the heads for compression releases ? If so, I would install them and if not I would start by checking out the electrical system. Even if the electrical checks out, you may have to have the heads drilled.
Big_Al47
May 10, 2017 07:31 PM
Ryan_1200
Dec 22, 2016 09:30 PM
bwz123
Oct 26, 2010 11:47 AM
MJR
Feb 8, 2009 12:25 AM
Night_Train01
13
Aug 27, 2006 10:13 AM
