bike rear-ended; something seems wrong...
Old May 12, 2006 | 08:00 PM
Hitecrednek's Avatar
Hitecrednek
Default bike rear-ended; something seems wrong...
My 883 was rear ended last fall; it has been fixed (bet that kids insurance is sky high now!)......it was a low speed hit, the back fender was almost folded over in half, and the rear tire had to be replaced.....
so, it was repaired by dealear, and they did a good job, but now the bike doesn't sound the same....it almost sounds like something in the lower part of the enginge/gearbox is loose; sort of a low pitched metallic rubbing sound at times. Also, the bike has more vibes than it used to. Shifting seems a bit clunky, especially at low rpm, but that might be normal.
I'll probably take it in and have it checked out, but if anyone can offer a suggeestion for what to have looked at, that would be helpful.
Old May 13, 2006 | 01:43 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default RE: bike rear-ended; something seems wrong...
Did they align the bike completely?
Old May 14, 2006 | 01:43 AM
Hitecrednek
I would think so, but I'll put that on my list of things to check....thanks.
Old May 14, 2006 | 01:51 AM
Shovelhead Bob's Avatar
Shovelhead Bob
Did they repair or replace the Swing Arm/ Bearing Sets?
What do the Motor Mounts look like?
Any oil or seepage around the starter motor mounting at the primary?
I'd first go with the Swingarm/Bearings.....
Then to the Motor mounts....
Old May 14, 2006 | 06:16 PM
Hitecrednek
no oil seepage; not sure about the other things....but, like I said, this is all good stuff to suggest they look at-thank you.
cvaria
Feb 23, 2017 02:46 PM
bikerlaw
EVO
59
Nov 19, 2014 07:44 PM
TO34
Sep 10, 2010 03:25 PM
txbikerboy
Jul 18, 2007 11:03 PM
oldgeezer
Jul 25, 2005 06:59 PM
