turn signal(s) problems
Old Oct 13, 2003 | 04:43 PM
duke's Avatar
duke
1st Gear
Default turn signal(s) problems
<DIV><FONT face="Trebuchet MS" size=2>75' XLCH 1000 Ironhead Sporty.</FONT></DIV>
<DIV><FONT face="Trebuchet MS" size=2></FONT></DIV>
<DIV><FONT face="Trebuchet MS" size=2>I seem to have a problem(s) with the directional turn signals:</FONT></DIV>
<DIV><FONT face="Trebuchet MS" size=2>A few weeks ago, both myright side would intermentedly work, and it appeared I had a problem with the button on the handle bar, so after I took it apart and cleaned it up, both rightturn signals workedfine.</FONT></DIV>
<DIV><FONT face="Trebuchet MS" size=2>Now, m</FONT><FONT face="Trebuchet MS" size=2>y "left rear" works fine, my left front does not work, and my both rightturn lights sometimes work, but are not very bright, and when I push the right side turn signal button in, I can barely hear the directional signal flash switch which I believe is located inside the headlight compartment.</FONT></DIV>
<DIV><FONT face="Trebuchet MS" size=2>All the bulbs appear to be ok, as I tested them in theleftrear which is very bright! I tried to clean-up the brass contacts inside each of the turn signal bulbs (Plastic Lens) and sprayed some cleaner in there, but have the same problems.</FONT></DIV>
<DIV><FONT face="Trebuchet MS" size=2>I am wondering if I am having a problem with the Directional Signal Flasher Switch inside the Headlight assembly - as when I push the left turn signal button in, it has an audible sound, and a somewhat fast click to it, but on the right side, when I push in the button, sometimes the lights come onbright, then not at all or when the lights barely come on, the Directional SignalFlasher Switch is much less audible and slow in clicking?</FONT></DIV>
Old Oct 14, 2003 | 11:02 PM
duke's Avatar
duke
1st Gear
Hey Everyone,</P>
I found and fixed the problem.</P>
It was in the right turn signal "button" switch.</P>
Once I removed the old one and soldered on the new - it worked like a champ . . . .</P>
"THX" to each of you, for your interest and replies!</P>
Duke
</P>
Gil935
Mar 30, 2016 07:26 PM
LoneWoolf
Electrical/Lighting/Alarm
Dec 14, 2015 01:20 PM
Winston74
Feb 17, 2015 06:24 PM
bobbytouche
Nov 2, 2013 03:50 PM
duke
General Topics/Tech Tips
Oct 13, 2003 04:41 PM
