Re Starting Problems after running
Old Oct 10, 2010 | 09:20 PM
Blackheat's Avatar
Blackheat
Default Re Starting Problems after running
I have an 08 Road King with just over 10K on the miles, after the bike has run a few min if I shut it off then try and re start the bike doesn't always start up, most times yes but not all the time which makes this harder to track down. All wires and connections are tight. It makes a strange noise, and sometimes I have to keep starter button down longer then normal.
Old Oct 12, 2010 | 01:55 PM
mkguitar's Avatar
mkguitar
most electrical problems are dirty connections ( which is why swapping parts often 'repairs" a problem, the connections are cleaned and secured when the parts are swapped).
suggest you disconnect the battery cables at the battery end.
disconnect them at the other end ( starter and frame or other chassis connection).
clean the lugs with sandpaper or wire brush ( just brighten them up)
connect everything up again negative cable to the battery - last.
and that might well solve the problem.
bad connections can be made worse with heat ( resistance is higher).
IF you hear a whining noise from the starter and it is not turning- let go the button- the windings are cooking.
mk
Old Oct 12, 2010 | 07:45 PM
Blackheat's Avatar
Blackheat
THANKS! will give it a try.
Old Oct 26, 2010 | 11:02 PM
FLHTom1948's Avatar
FLHTom1948
Ah, yes; sandpaper. the great equalizer. If only firearms were as easy to fix. (off topic?)
Old Oct 27, 2010 | 12:32 AM
arealinvestor's Avatar
arealinvestor
Check your tune,or lack of tune??
SouthBayRay
Electrical/Lighting/Alarm
Jun 3, 2016 06:42 PM
StephenBooth01
Shovelhead
27
Jan 30, 2015 09:34 AM
typennies79
Mar 27, 2014 08:23 AM
84sugar
EVO
Mar 23, 2008 11:46 PM
mnmpierce
Jan 29, 2006 12:40 PM
