Front Injector Problem (Baggers)**
Old Jun 22, 2005 | 06:06 PM
pilot1996's Avatar
pilot1996
Default Front Injector Problem (Baggers)**
Submitted by TCSTD:
Tech Tips Online
September 09, 2002
Front Injector Harness On Touring Models
You may encounter an intermittent hesitation and historic front injector code,
P0261, on Touring models. If so, the condition could be caused by broken wires in
the ignition harness very close to the injector. Since the insulation is not damaged
the break cannot be seen. Wiggle the harness to determine if the condition exists.
If you do find a broken wire, it is likely due to a mis-positioned tyrap causing the
wires to the front injector to be pulled tight. The combination of insufficient slack
and engine movement can cause wire flex leading to the breakage. When you
repair the wire, be certain to allow slack in the ignition harness to prevent a
recurrence.
You can move the harness around by the injector plug and see if the engine stumbles when you do this. It will give you an indication of the problem if this is where you have a break in the wire.
For info on pulling the codes click here.
Source: http://www.harleyhog.co.uk/
butterballs
The Dyno Room
Mar 1, 2017 06:57 AM
ernster500
Apr 4, 2014 06:34 AM
07DYNAGLIDE
Oct 11, 2010 03:39 PM
zenwarrior
May 21, 2007 05:23 PM
HDF Tech
Jan 3, 2006 05:35 PM
