gary
Old Feb 10, 2011 | 01:07 PM
GARY CROSSLEY's Avatar
GARY CROSSLEY
Stage II
Default gary
dipstick blows out on 1998 fxd, to much pressure in oil tank . don't know why
Old Feb 11, 2011 | 11:22 AM
cateyetech's Avatar
cateyetech
The motor and oil tank vent through the bolts that hold the air cleaner to the heads. Check to see if there clear, If they are clear then you may have a bad breather valve or too much cylinder ring leakage. Good Luck.
Old Feb 21, 2011 | 07:34 AM
GARY CROSSLEY
Stage II
could it be the umbrella gaskets in the heads ?
Old Feb 21, 2011 | 10:08 AM
cateyetech's Avatar
cateyetech
Gary, they would have to be stuck shut, usually they curl up and dont seal. I'd run it by your local shop and have them check you cylinder leakage with a gage set (should be less than 40%) It's quick and should'nt cost much. Good Luck
Fatkid1979
Sep 27, 2018 06:15 PM
Arend
Engine Mechanical Topics
Feb 19, 2015 04:41 AM
jh2pizza
Apr 16, 2011 12:07 PM
bdyson250r
Exhaust System Topics
Dec 27, 2010 12:42 PM
mrbikeuk
Oil Archive (no new posts)
Sep 15, 2007 07:15 AM
