Tank Insert Removal, NEED HELP
Old Dec 15, 2006 | 12:08 AM
Stroker Ace's Avatar
Stroker Ace
3rd Gear
Default Tank Insert Removal, NEED HELP
I have an 05 Electra Glide Standard and want to remove the stock plastic tank insert to install a leather pouch. Any help appreciated.
Old Dec 15, 2006 | 08:44 AM
dawg's Avatar
dawg
Default RE: Tank Insert Removal, NEED HELP
Mine is just glued down, take a small putty knife or something and gently pry up the corner then pull 'er off. I've had mine off then back on again without any problem.
Old Dec 29, 2006 | 10:04 AM
mcb's Avatar
mcb
Just like Dawg said. I have also seen some leather tank inserts that have been actually secured with fasteners. In order to that,it needs to be removed and drilled if you want to go that far. Find a good glue and maybe rough up the back side of the leather to improve adhesion.
nzhd
Jun 17, 2018 08:41 PM
cary713
Jun 11, 2010 08:36 AM
dashiell
Nov 28, 2007 03:47 AM
jdduvall
Feb 25, 2007 04:32 AM
Stroker Ace
Dec 15, 2006 09:08 PM
