Tank Insert Removal, NEED HELP
Old Dec 15, 2006 | 12:10 AM
Stroker Ace's Avatar
Stroker Ace
3rd Gear
Default Tank Insert Removal, NEED HELP
I have an 05 Electra Glide Standard and want to remove the stock plastic tank insert to install a leather pouch. Any help appreciated.
Old Dec 15, 2006 | 09:33 AM
harleygunnow's Avatar
harleygunnow
Default RE: Tank Insert Removal, NEED HELP
Hi
The plastic piece is glued on. In a warm environment pry it off working your way around the edges. Careful not to scratch the chrome. It will come off quite easily. You might be disappointed about putting a leather bag, as the backing is not solid and part of the tanks electrical wire is exposed. You can also remove the entire console and try to remove the insert that way. I took mine off and made a new insert, was easy to get off and used some gorilla glue to glue the new insert back on. Good luck and be patient.
Old Dec 15, 2006 | 09:08 PM
Stroker Ace
3rd Gear
Was just a little nervous but came right off like you said. Thanks!
harleyfire18
Oct 2, 2021 01:14 AM
Diximix
Mar 7, 2016 01:42 PM
jdduvall
Feb 25, 2007 04:32 AM
Stroker Ace
General Topics/Tech Tips
Dec 29, 2006 10:04 AM
SFTail06
Jun 10, 2006 11:36 PM
