Replacing Grips
Old Aug 14, 2012 | 08:33 AM
Dually_TG's Avatar
Dually_TG
Default Replacing Grips
With the new electronic throttle control, how hard is it to replace the grip? I've done it a couple times on the cable type, but there must be something different here. Thanks
Old Aug 16, 2012 | 01:01 PM
Arctic miner's Avatar
Arctic miner
6th Gear
I have just changed the handlebars and new heated grips. It was an easy job. Just remove the housing for the brakehandle, and then you can pull the grip off. You need a new grip that is built for the drive by wire system.
Old Aug 16, 2012 | 01:10 PM
SIDECAR BOB's Avatar
SIDECAR BOB
easier the the old cable type
Old Aug 16, 2012 | 01:16 PM
So-Cal Street Glide's Avatar
So-Cal Street Glide
Super easy. Make sure you buy the right type of grips for electronic throttle first. Undo the switch housing on the throttle side remove old grip, push new grip on and refasten the housing around the grip when you have it in position. There will be some slight play but that is normal. No need to remove switch housing on left side, the grips are different and that side just glues on flush with the sticky two sided tape that is provided. Good luck.
Wranglin4Life
Mar 28, 2015 12:14 AM
EasTexUltra12
Apr 5, 2013 01:57 PM
hogdiver96
Mar 27, 2013 12:18 PM
Bugspit
Dec 19, 2010 09:38 PM
jcanrun
May 17, 2010 12:01 PM
