Pinching Pennies
Old Nov 27, 2012 | 07:26 AM
dead wait's Avatar
dead wait
Default Pinching Pennies
I'm not sure if this is the right place to post this but, here it goes.
If you drill out the stock baffle from a stock muffler, can it be replaced with an after market baffle?
If so, how do you prevent blowby from where it was drilled? Assuming you didn't go much bigger than the actual baffle itself.
Next question. If you cannot use an aftermarket baffle, should you drill the hole large enough to remove the packing around the baffle?
As the title say's, trying to save a dollar..
Old Nov 27, 2012 | 04:15 PM
UltraNutZ's Avatar
UltraNutZ
for better exposure you should post this in the engine-fuel-intake-exhaust section located here
Old Nov 28, 2012 | 05:54 AM
dead wait's Avatar
dead wait
I think I should just close this thread. Problem solved. I put on a set of screamin eagles.
pmcburne
May 30, 2010 07:38 AM
maineultraclassic
Aug 27, 2009 02:14 PM
chuck2000RK
Exhaust System Topics
Dec 28, 2008 02:14 PM
tah796
Oct 3, 2008 12:25 PM
HarleyWood
Nov 7, 2007 05:00 AM
