Brake Lights Staying On
Old Aug 12, 2005 | 09:26 PM
HDF Tech's Avatar
HDF Tech
Default Brake Lights Staying On
If you encounter the brake lever causing the brake light to flicker or stay on without use of brake, it may be due to the piston return spring not returning to proper length. This leaves lever with free play and does not contact the brake light switch properly. To correct this situation, you should use a master cylinder rebuild kit. This condition also will cancel cruise control or not allow cruise to be activated.
crowbar7817
Electrical/Lighting/Alarm
May 23, 2018 06:45 AM
Marks57
Mar 27, 2017 10:22 PM
JRH232
2014-2024 Touring Models
Feb 25, 2014 11:18 AM
BLLYGOAT
May 24, 2008 10:31 AM
dsolsbery
May 5, 2007 04:10 PM
