Clutch replacement on an 08 touring
Old Jul 30, 2013 | 08:27 PM
danroo's Avatar
danroo
Default Clutch replacement on an 08 touring
I have a 2008 FLHTCU and the clutch is failing at 80,000 km. I am looking for a new one any suggestions as to what to use other than OEM? I do not want a hard pulling clutch, I want to change all steel and friction plates, also I think I need to change the finger plate as well....any suggestions?
Old Aug 6, 2013 | 12:51 PM
grbrown's Avatar
grbrown
I just installed a Barnett plate set, frictions and steels. Probably the best known clutch plate aftermarket brand. You may find them on Ebay!
Old Jan 6, 2014 | 02:41 PM
Grimace97's Avatar
Grimace97
I have a 97 king. Swapped out the plates for a barnett set when the spring plate with the rivots exploded.
Very happy with the barnett.
Old Jan 6, 2014 | 06:01 PM
qtrracer's Avatar
qtrracer
Although I generally like Barnett stuff unless you were having issues and can source the oem fibers and steels at a good price, I'd go oem. I would change the spring to a stiffer spring. I used AIM for their 340lb spring but there are oem 330 and 300lb springs available, I just don't know the part numbers. Your 08 spring(finger plate, lol) is a lite spring like 260.
Old Jan 6, 2014 | 08:00 PM
GraemeR's Avatar
GraemeR
Man this thread died yonks ago!
drinktothat421
Aug 18, 2025 12:19 PM
RLH3175
EVO
Sep 3, 2017 11:53 AM
notofthisworld
Dec 31, 2012 07:34 PM
blacksportster05
Jul 7, 2012 10:53 PM
Bankrupt
Mar 3, 2012 03:34 PM
