Ultra handlebar adj.
Old Oct 6, 2013 | 05:51 PM
Tinmanpope's Avatar
Tinmanpope
Default Ultra handlebar adj.
Need little help here. Worried about ignition switch break down , how far?
Old Oct 7, 2013 | 05:50 AM
sdecgreen's Avatar
sdecgreen
I am interested too...
Old Oct 9, 2013 | 08:06 AM
Tinmanpope's Avatar
Tinmanpope
I haven't forgot about you just trying to get some attachments and help you out my mechanic helped me over the phone.
Old Oct 9, 2013 | 12:49 PM
Tinmanpope's Avatar
Tinmanpope
Default handlebar adj.
Here are a few places to look at videos
First, view this:
If that doesn't work, go here: https://www.hdforums.com/forum/touring-models/460642-video-of-ignition-switch-removal.htmlNext, go here: https://www.hdforums.com/forum/touri...h-removal.html
I watched first video and got an idea of what to do
1. turn bike to far left to the lock position,
2. turn ignition switch **** to the far left, as if you were locking it
3. insert key into switch turn to left, while reaching under the ignition switch **** there is a small button on the left underneath side of **** push it up and **** should come off. Be careful there is a spring that will come out too
(take a magic marker and mark down the whole side this is just a precaution if any orientation is lost.
4. take a 7/8" open end wrench and loosen nut on top, take it off
5. next take the collar off it has one fat key and a slinder key to orientate
6. take spacer off, this should get you where you are down the the fairing dash part.
7.pull the dash back to get to the back two bolts loosen them with allen wrench, adjust handlebars and then reverse to install back.
Hope this helps.
Attached Thumbnails Ultra handlebar adj.-iphone-547.jpg   Ultra handlebar adj.-iphone-548.jpg
GRUNT77
Oct 30, 2018 07:46 PM
electralight
EVO
Jul 28, 2016 07:27 AM
bobby5
Apr 24, 2009 03:52 AM
MassHD
Oct 29, 2008 09:14 AM
Warden
Sep 6, 2007 01:08 AM
