I need help with my ignition switch
Old Oct 28, 2008 | 05:55 PM
MassHD's Avatar
MassHD
Default I need help with my ignition switch
Well only I could do it!! I was trying to a line the tubblers when I hit a snag. T thought I was all set but once I put the unit in the hole and turned it locked in place. I can move my bars left and right fine but the switch is stuck facing the left side of the bike. Any help please!!!!!
Old Oct 28, 2008 | 06:18 PM
blueflht's Avatar
blueflht
try compressing the tab under the switch and remove the ignition. i did the same thing as you and spent 2 hours playing with it to realign.
Old Oct 28, 2008 | 06:24 PM
SG 1's Avatar
SG 1
Insert the key and turn it to the left while holding the button underneath, it should come out. Turn the hole thing around until you find the slot. Good luck, mine got stuck too. Just keep foolin with it, it will come out.
Old Oct 28, 2008 | 06:43 PM
dawg's Avatar
dawg
Whoops, I misread your PM and didn't realize that you had the button pushed down and stuck, I thought you were still trying to align the tumblers. Anyhow, like stated above....a lil foolin' and push the tab underneath again and it should come off. I've done that before too.
Old Oct 29, 2008 | 09:14 AM
MassHD's Avatar
MassHD
Thanks guys I got it off late last night. I will try to put it back on again tonight.
M8USA
Nov 16, 2018 10:35 AM
GRUNT77
Oct 30, 2018 07:46 PM
bearammus
Mar 6, 2014 08:08 PM
bobby5
Apr 24, 2009 03:52 AM
Warden
Sep 6, 2007 01:08 AM
