Ignition switch
Old Nov 9, 2018 | 07:14 AM
M8USA's Avatar
M8USA
Default Ignition switch
2017 ultra limited FLHTKL; Ignition switch keeps getting stuck in different positions with or without key, but usually in lock position. After a few tries I am able to get it to release. Brought the bike into my dealer but both times could not duplicate condition. They lubed it and sent me on my way. So I am now down south and towed my bike into a dealership with a flat tire. I told the service rep that the ignition switch still keeps hanging up. He said that he sees this problem about once a week.
His solution was DO NOT put the cylinder in the lock position. How can I get them to replace the switch. Warranty runs out at end of year.
Old Nov 9, 2018 | 07:19 AM
PDB17UltraRG's Avatar
PDB17UltraRG
I would demand they change it its been a problem for a while now.
Old Nov 9, 2018 | 12:36 PM
hardheaded's Avatar
hardheaded
There is a little screw under the sticker on the top of the switch right above the key hole. Remove the metal sticker with a feeler gauge and take a 25 secuity torx bit and while someone holds the switch down remove and reinstall after applying redlock tite. Replace sticker. Do a search on here there are a couple of threads on it. At least that is what is claimed to be a problem and i did it before i had problems.
Don't know if that will solve your problem or not but it's worth a shot.
Old Nov 9, 2018 | 12:41 PM
TriGeezer's Avatar
TriGeezer
Mine sticks sometimes too. It seems very sensitive to how I turn the ****, how far I turn the bars, and when I press in and rotate the lock,
Old Nov 9, 2018 | 01:18 PM
ORradtech's Avatar
ORradtech
I haven't read or seen anything on this problem yet BUT I would never use RED loctite on that screw. Blue sure, but the thought of trying to remove a tiny torx screw with Red from the ignition switch makes me cringe...
Old Nov 9, 2018 | 05:35 PM
hardheaded's Avatar
hardheaded
If you ever needed it out all you would have to do is hold a soldering gun on it until the lock-tite lets loose.
Someone else told me about this problem after not being able to unlock their forks. So i would assume it could cause the switch to hang up. It seems when this screw gets even slightly loose it can cause headaches. This is why they tell you not to put it in the lock postion. I think many techs have seen this problem before. That little screw is not on any parts list or pic's either.
Old Nov 11, 2018 | 07:46 AM
M8USA's Avatar
M8USA
So if you do not put it in the lock position then what stops someone from rolling it away.
Old Nov 16, 2018 | 10:35 AM
CalgaryBikeBum's Avatar
CalgaryBikeBum
Probably a different switch but mine on my 2011 locked and would not release at all. I was on a 3 day bike run 7 hours from home. Had to strip it out (wasn't easy but doable) and jump ignition to get it running. When I went to HD to get a new one they said they were back ordered for 3 months??? I got a new one off ebay that has worked great. I also turned my keyfob security back on so bike would not start if ignition was unlocked (previous owner had it disabled at dealership). I usually leave it unlocked now unless it's night time away from home. Guy on parts counter said they had lots of people coming in looking for a new one so must have been an issue of some sort???
GRUNT77
Oct 30, 2018 07:46 PM
Watchfuliz
2014-2024 Touring Models
16
Jan 17, 2015 09:40 AM
bearammus
Mar 6, 2014 08:08 PM
tombeving
Nov 22, 2011 12:28 PM
SparkyRKM
Aug 29, 2007 12:42 PM
