Need help fast
Old Sep 5, 2007 | 08:39 PM
Warden's Avatar
Warden
Default Need help fast
Hello all, I am trying to do the passing light/ high beam wiring. I need to know how in the hell to remove the ignition switch indicator plate to remove the switch console or else the silver thing under the actual turn switch.
Please help as soon as you can.
Thanks,
Warden
[IMG]local://upfiles/35743/A0FB384FD33C42FFBBE6B503EDE08DB7.jpg[/IMG]
Old Sep 5, 2007 | 08:49 PM
PhilM's Avatar
PhilM
Default RE: Need help fast
Do you have a svc manual?
If you are talking about removing the ignition switch on an EG or RG, you need to be careful bacause you can get the steering lock mechanism outa line and if that happens, you'll have to take it in so a stealer cna fix it.
There is a button on the bottom side of the big chrome switch & you will have to put the key in the cylinder, turn it all the way to the right, and while you press the button on the bottom, you will have to rotate the whole switch to the LEFT past the lock position and it will then pull striaght out.
That;s from memory.... so I hope it's complete & right.
***TURN THE FORKS ALL THE WAY TO THE LEFT AND LEAVE THEM THERE UNTIL YOU PUT THE LOCK ASSY BACK IN PLACE OR YOU WILL HOSE THE STEERING LOCK REFERRED TO ABOVE***
Hope this helps....
Old Sep 5, 2007 | 08:50 PM
maineultraclassic's Avatar
maineultraclassic
Just unscrew it, there are flat sides on the top for a wrench to fit to. Just unscrew it and it will all come right off.
Steve
Old Sep 5, 2007 | 09:13 PM
PhilM's Avatar
PhilM
oh...
Guess I shoulda looked at the picture!
Steve is right, just unscrew it....
Old Sep 6, 2007 | 01:08 AM
Warden's Avatar
Warden
Thank you for all the help. You are right about the steering. I spent about 45 min trying to get all lined back up. For others that might do this, if you take the two screws out of the entire ignition it will re align.
I am far from a mechanic although if anyone wants to do the pass lamp/high beam mod, and need hel, I can help.
Again, thanks for the help.
Warden
electralight
EVO
Jul 28, 2016 07:27 AM
Brass Monky
General Topics/Tech Tips
Jun 22, 2016 01:54 PM
bobby5
Apr 24, 2009 03:52 AM
MassHD
Oct 29, 2008 09:14 AM
hobbes2
Apr 20, 2007 10:19 AM
