Handlebar access.
Old Apr 20, 2007 | 01:08 AM
hobbes2's Avatar
hobbes2
Default Handlebar access.
Picked up my new sg today . Need to find out how to gain access to bar clamp . The plastic cover comes off but am not sure how to remove the key and switch or if i even need to . Any help would be great . Thanks
Old Apr 20, 2007 | 05:44 AM
Wally's Avatar
Wally
Default RE: Handlebar access.
You need to remove the key switch.
Best advice i can give you is,
Buy a manual!
It's worth every penny, even if you only use it this once.
Old Apr 20, 2007 | 05:52 AM
Pacemaker's Avatar
Pacemaker
ORIGINAL: Wally
Buy a manual!
[sm=exactly.gif] I second that, "it's worth every penny."
Old Apr 20, 2007 | 08:50 AM
jbhawley's Avatar
jbhawley
to remove the key switch is a very aggrivating operation the first couple times you do it...then you will eventually figure it out and it comes off easily.
In a nutshell
[ol][*]get a small flat tip screwdriver...a real smal one[*]feel with you fingers the underside of the actual switch. This is the part that turns from OFF > IGNITION > ACCESS.[*]At about the 7:00 position on the underside you will feel a small 'button'. Remember where that is.[*]Turn the switch to the ACCESS position[*]Take the screwdriver and push the button upwards as if you are trying to push it into the actual switch. You will feel it 'give' a bit.[*]At the same time Insert your key and turn it counter-clockwise (opposite from the LOCK position)[*]The switch will pull out of the housing.[*]To insert the switch just reverse the process.[/ol]The button releases the tension on the latching mechanism. Turning the key in the opposite direction releases the locking mechanism that holds the switch to the housing. Putting the switch in the ACCESS position makes the keyway line up correctly. It should complicated, but it really isnt. It tooke me 45 minutes or so to figure this out the 1st time i tried it...thats after reading the manual. Now i can remove my swith in 5 seconds.
Old Apr 20, 2007 | 09:06 AM
hobbes2's Avatar
hobbes2
Thank you all ,I will take your advice.
Old Apr 20, 2007 | 10:19 AM
Wally's Avatar
Wally
Once the switch is removed, there is a nut. Pay attention to how tight the nut is when you remove it.
I find snug is good when reinstalling , as you will be using a fairly large wrench.
Also, as you remove stuff, turn it upside down on the bench and put the pieces back on the upside down switch to help with the order when assembling.
Rznkane
Dec 29, 2012 01:16 PM
67wizard
Jul 19, 2012 12:26 AM
cwsharp
Oct 23, 2011 03:52 PM
andyp
Jan 7, 2011 08:11 PM
Jinxie
EVO
Aug 27, 2007 09:24 PM
