Problem Ign removal
Old Dec 24, 2010 | 08:05 AM
andyp's Avatar
andyp
Default Problem Ign removal
Having a problem with removing my ign on my 4 flhtc.I have done this before 3 or 4 times but not this time. I turn ign switch to acc in unlock poss with key installed I depress button on botton of switch housing and turn key and additional 60 degrees and I can feel it come up abit but it still will not lift up all the way,something is still engaged ?I tried moving to run poss and lock with no luck .
Old Dec 24, 2010 | 08:26 AM
CLL375's Avatar
CLL375
Try turning it to the lock position first, them follow the other steps.
Old Dec 24, 2010 | 08:42 AM
Freebee's Avatar
Freebee
iClick's walkthrough :
It is really very easy once you get the hang of it, and you can pull it off in one second. You don't really need a screwdriver, as stated in the manual, if you have small fingers and can push the tab under the switch with a finger while turning the ignition key CCW. Start at the Lock position, push up on the tab with a finger or small screwdriver blade, turn the key CCW about 60°, and pull the switch **** up and out.
Make sure you remember the correct position of all the switch parts for reassembly and don't attempt to move the switch to any other position unless all parts integral to the **** (2 collars and a nut) are in place. I made the mistake of inserting the switch **** without the collars and nuts by mistake to move the switch off Lock to move the handlebars, and got the internal mechanism out of whack. I thought I would have to trailer it to the dealer, but using a flashlight and flat-blade screwdriver managed to get the switch mechanism back in alignment. There are two moving parts to the switch mechanism inside the shaft hole, and if they get out of alignment the **** won't fit properly and the switch won't work.
The point is that you may need to insert the switch **** in to unlock the handlebars to re-attach the fairing switch cap, as it is a tight fit. Just make sure everything is in place (collars and nut) before attempting it.
Old Dec 24, 2010 | 08:51 AM
andyp's Avatar
andyp
Tried that ,no different.
Old Dec 24, 2010 | 10:23 AM
Harleypingman's Avatar
Harleypingman
From the '04 HD Touring SM:
2. To remove the ignition switch ****, insert the Ignition
Switch key and turn to the UNLOCK position. Leaving
the key installed, rotate the **** to ACCESS. Depressing
the release button at bottom (left side) with a small
screwdriver, push key down and turn an additional 60
degrees in a counter-clockwise direction. Lift and
remove ****. See Figure 8-61.
Good luck and Merry Christmas to you and yours.
Carl
Old Dec 24, 2010 | 07:02 PM
Roadie09's Avatar
Roadie09
Try spraying a little lubricant up inside the switch where the key and release button are located. Mine was being a little difficult on the last removal and the lubricant did the trick.
Old Dec 24, 2010 | 07:12 PM
SpiderPig's Avatar
SpiderPig
Try this thread.
https://www.hdforums.com/forum/touri...h-removal.html
http://www.youtube.com/watch?v=7-QBH1SFyzo
Old Jan 6, 2011 | 09:02 PM
5point56's Avatar
5point56
Thank you for posting this, I just had this problem.
This is what I love about this site.
Old Jan 6, 2011 | 09:10 PM
grandparon45's Avatar
grandparon45
Great video and info there, thanks, a movie is worth a few thousand words.
Old Jan 7, 2011 | 08:11 PM
Lunch Meat's Avatar
Lunch Meat
Thanks for the video, really helpful
crash_override65
May 24, 2016 09:04 PM
Watchfuliz
2014-2024 Touring Models
16
Jan 17, 2015 09:40 AM
67wizard
Jul 19, 2012 12:26 AM
gwphelpss10
Jun 14, 2012 11:36 AM
hobbes2
Apr 20, 2007 10:19 AM
