How do you tap out a hole???
Old Feb 21, 2014 | 07:29 AM
Jackie Paper's Avatar
Jackie Paper
In the thin bars, you should have no problem tapping the hole. Even a small adjustable wrench will do it. Just tighten it and then grip it like a one legged T-handle. The idea of a T-handle is to keep the tap square to the hole. Especially on smaller taps, if you get off square, it's very easy to brake the tap since it starts hitting no hole (hope you understand what no hole is? HA) Once started, taps pull there way in, so other then getting started, it take little downward force. Just do not wobble it in that thin wall or you will have an oversize loose thread. If you are just doing the tube, drill the hole slightly smaller then what the chart says for the tap drill. The recommend tap drill chart is for 75% or so of full threads and leaves a flat on the minor diameter of the thread. In thin wall, you want 100% thread. Drill it so the end of the tap just starts. You really want a #3 starter tap but a #2 will work fine. A bottom tap (#1) is quite hard to start and is only necessary in blind holes that you need full strength but can only drill so far. You use a 3 or 2 before running a 1 to finish. Use a little motor oil for a lubricant.
dulley
Jul 9, 2013 06:57 AM
street bob 59
Jun 26, 2009 02:03 PM
Rat bike
Ironhead
Jun 27, 2008 11:02 AM
roxnatwist
Feb 19, 2008 07:06 PM
