2014 FXDB handlebar change
Old Sep 2, 2014 | 09:50 PM
Nbart3845's Avatar
Nbart3845
4th Gear
Default 2014 FXDB handlebar change
Just looking for some advice. Going to be changing out the handlebars of my 2014 street bob and was wondering if I should follow the service manual exactly and fully purge and remove the fuel tank. Also for the clutch to do a full adjustment requiring the removal of the clutch plate and all that...or to just loosen the line and then retighten. I would greatly appreciate any advice given. Thanks
Old Sep 3, 2014 | 06:35 AM
grbrown's Avatar
grbrown
I can't see any need to remove the gas tank, however you do need to protect it carefully! As for the clutch, if you are going to use the same cable you shouldn't need to disturb the cable at all, simply undo the clamping screws and lay the control lever out of the way as you work. Same comment applies to the brake master cylinder, however don't turn it upside down, as it may leak. If you are fitting taller bars that require longer brake lines ans clutch cable, etc, that will require more work, but still doesn't need to involve removing the tank or disturbing the clutch.
flyeryder
Feb 5, 2017 08:34 AM
c50plus
Feb 23, 2010 02:00 PM
Pipedream
Apr 19, 2008 07:57 PM
06SportsterCstm
Sep 3, 2007 03:14 PM
Bill918
Dec 28, 2005 11:18 PM
