Hacked, Conversions and Trailering"Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts"
A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
As a former Albertan, I'm sympathetic to the high cost of buying in the States these days! I bought the Trans-Moto and have no regrets. PM if you have any questions.
Gorgeous! Did you buy it in Alberta? Did the dealer set it up? I notice a shock for the 3rd wheel?
I originally bought the car from TransMoto for an 05 Superglide. After 3 years with it, I had some changes in mind. With a new Slim S in 17, I wanted to lower the car to better match the bike and gain on performance; improve its funkiness by matching the cars wheel with the bike - I ordered a second front wheel when I bought the bike and putting on a half fender, exposing most of the wheel; and improve the ride - touring bike gas shock. The installer was Metalmorphosis (Brock Smith) in Kamloops, BC.
I sought to increase the cars weight (stock, its pretty light): new, heavier duty frame; spray in truck liner inside the car; and a full size AGM car battery to replace the motorcycles battery. Now the car comes in at about 250lbs and the rig handles beautifully. More funk - handmade aluminum dash with instrumentation (clock, voltmeter and ammeter), internal lighting, Power outlets, switched and unstitched fuse boxes, etc.
its what I wanted now - performs and handles great and I use it for the long-distance, traveling I like to do ... Ural, its not!
You have assembled a fine looking rig. And from the sound of it you have it doing what you want it to do. Each person needs will be different. A big one of me is a car tire on the sidecar and bike rear. Not such a big deal if you ride low miles but if you really use them it adds up.
After having rigs with and without ECC. Unless it was a small light rig I would be without it.
Like your idea I want to mount a small car battery in the sidecar. With heated seat and heated blanket it would be a good idea. When it starts getting cold these new bikes are harder to start.
I am often shocked at the false information about sidecars I hear. Like the one you can't keep up with traffic.
Did any of you have to install a set of raked trees. My 65 utilizes adjustable trees.
I think when Liberty Sidecras was in business they sold raked trees for both springer front ends and for the standard forked models
I have not on my Crossbones. It is an upper body workout when making slow speed lefts and rights like at 4-way stops. And there is a little slow speed wobble that demands I hold onto handlebars with both hands. Other than that, I am not seeing enough need to go that route. Of course I'm not traveleing the great north west like exocelis does. Just around town for 30 minute cruises.
Love what youve done. The Crossbones has the right look, for sure. As for the steering, theres an old posting in the Adventure Rider forum, Reducing Trail on a Harley Springer Front End that addresses the issue with the Crossbones. Might be a workable solution - involves altering the springers links.
Get the word out DMC will be offering some lower cost but good sidecars. Prebuilt other than their normal order first system. They will no lower cost but not Cheap sidecars.
