Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Sidecar question
Old Nov 28, 2018 | 09:25 PM
hobbles-1's Avatar
hobbles-1
Evening smitty901 .
"looks like you rear lower mount is to far forward. "
I'll have to check that out in the morning, it is a soft tail so I can only go back so far.
I got all day tomorrow to find and print out pictures of how others are done, any and all pictures would help.
Old Nov 29, 2018 | 07:07 AM
smitty901's Avatar
smitty901
Originally Posted by hobbles-1
Evening smitty901 .
This is my 563 mounted on a 1996 FB softail it spent all most 4 years on that bike. It may take time but you will get it right. You need a Flat place to do it or you will just be chasing your tail.
[url=https://flic.kr/p/24oWFRM]
Steering dampener mounted on softail
Old Nov 29, 2018 | 07:21 AM
smitty901's Avatar
smitty901
This is a start for you. I have been at this awhile. The sidecar can be a lot of fun once you get it all worked out. Remember you drive a sidecar you ride a bike two different worlds.
https://www.velorexusa.com/Instructi...structions.pdf
Save your self a lot of problems .
Work on a flat floor. Take shell off. Make darn sure you bike is blocked straight up so it can not fall over, Make sure upper mount don't hit the bike when not attach they do damage. Go slow think through each step. do not over tighten anything until you have it ready to test. The mounts can be reversed , flipped over what ever you need to do to get a good fit. The rear lower is often flipped.
You will need a Steering dampener with the front end. On lighter bike and light sidecar you can get away without a rake generally. Also remove windshield unless you must have it. Creates a lot of drag. Be careful with it $200 to replace
When not working on it read this. A good starting point
http://www.motorvation.com/scmanul1.htm
http://sidestrider.com/steering.htm
Old Nov 29, 2018 | 07:22 AM
hobbles-1's Avatar
hobbles-1
Thanks again @smitty901 , I have a flat spot for this Saturday, and it's going to be dry too. More rain coming. It's in my neighbors garage. He has all the equipment we gonna need. He did ask me to get some close up pictures of other setup, then we will design and build my setup.
Old Nov 29, 2018 | 07:26 AM
hobbles-1's Avatar
hobbles-1
Thanks for the pdf file3. I printed that out a few days ago and we both looked at it and talked a lil.
I don't think I will take the shell off tho. Why would I want too???
Old Nov 29, 2018 | 07:55 AM
smitty901's Avatar
smitty901
You may need to build a mount to move the lower rear back this is one I made for the 750 Street attaching to exhaust bracket and the channel runs to front peg mounts for support . Some time you need to get creative.
Old Nov 29, 2018 | 07:59 AM
smitty901's Avatar
smitty901
It is your ride your project. It takes 4 bolts to remove shell then it is out of your way. Easier to work on and take measurement and will save you a lot of effort.
Old Nov 29, 2018 | 08:34 AM
hobbles-1's Avatar
hobbles-1
Now that was some good info, 4 bolts,, cool.
Old Nov 29, 2018 | 09:07 AM
smitty901's Avatar
smitty901
When they talk about lean angle. That is how far the bike leans away from the sidecar keep in mind 1 degree is a starring point. A heavier ride may need a bit more but start with 1 degree. Strap your front end so it stays in line with the frame when working on it.
Noticed you are in KY.
Murry KY is home to one of the top sidecar brands Hannigan.
Old Nov 29, 2018 | 09:20 AM
hobbles-1's Avatar
hobbles-1
how do I delete this???
