Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Buell engine conversion question
Old May 8, 2022 | 02:46 PM
guidowitz's Avatar
guidowitz
Default Buell engine conversion question
I purchased a1999 Buell M2 Cyclone that had a engine transplant but I’m having trouble identifying the engine other than a 1200 “X”.
Engine case # KS11W300196. Any help identifying this engine appreciated, ( I can’t seem to be able to identify on the internet for some unexplained reason!) Cheers
Old May 8, 2022 | 04:02 PM
smitty901's Avatar
smitty901
With Buell the model year for the engine could be off 1 year . Need full vin to get more information.
The number you gave appears to be a Buell number.
KS means it is an M2 Cyclone The 11 means it is a world model Horse power code makes no sense
Old May 8, 2022 | 04:37 PM
guidowitz's Avatar
guidowitz
QUOTE=smitty901;20601308]The 11 means it is a world model Horse power code makes no sense[/QUOTE]
Could those be II and not ones?
Old May 8, 2022 | 05:31 PM
smitty901's Avatar
smitty901
Could those be II and not ones?[/QUOTE]
No they did not use an II in that section. The bike would have been one of 2 options a 11 world model or a 56 for CA model.
First ditgit would be country 4 means US
second 2 letters make MZ is Buell
3rd 2 letter KS means M2 cyclone
4 would be two numbers for engine type 11 is 49 states 56 would be CA
5 single letter Horse power code likely an H
6th 0-9 or an X just a VIN check
ECT.
Old May 8, 2022 | 05:55 PM
chopper_man's Avatar
chopper_man
Engine number is an abbreviated VIN.
KS11W300196
KS = M2
11 = 49 State model
W = 1998 year
30 = US model
0196 = sequence number
guidowitz's Avatar
guidowitz
BTW I am referring to the number stamped on the engine case not the frame. Someone transplanted an engine into this Buell and I’m trying to find out the specs on the motor only
Old May 8, 2022 | 06:04 PM
guidowitz's Avatar
guidowitz
Thanks for the clarification!
Old May 8, 2022 | 06:25 PM
smitty901's Avatar
smitty901
That is simple it is a KS a Buell M2 Numbers say it came off a Cyclone M2.
Hard part is finding out if anyone made any major changes to it.
Old May 8, 2022 | 06:56 PM
guidowitz's Avatar
guidowitz
As it turns out I have a 1999 Burell M2 California frame
with a 1998 49 state engine.
The 1999 has a horsepower code of “J”
while the 1998 engine has a horsepower code of “W”. Wondering if the non- California engine breaths better hence the reason for the swap
or if some other rational existed??
Old May 8, 2022 | 07:13 PM
smitty901's Avatar
smitty901
CA has had some EPA rules even back then that held the engines back.
Lunchboxx
Engine Mechanical Topics
Mar 2, 2023 10:37 PM
ksarauer
May 15, 2019 09:04 AM
Tampa Fatboy
"The Florida Crew"
Aug 13, 2015 09:37 AM
yellowpearlfb
Mar 28, 2015 09:08 AM
KingCripps
Apr 29, 2012 08:00 AM
